Well, for me the 907x + XCD 21mm is my new SWC, but I get your meaning. The 45P lens is a delightful "use it all the time" piece.That was my original idea as well . But as the 4/45P Lens is rather cheap and good , I could not resist . I don‘t know if Dante was involved here .Since the 907x body is likely such a small premium on the cost of the package (I can't see the back selling for much less than about $6000 standalone), I'd just buy a 907x and leave the body section in the box.
Now the 907x/45P kit is my new SWC .
I figure when I can afford to get one next year that is likely what I will do. I am 100% committed to the V system since that is where the bulk of my fine art works comes from. The D-back allows me to get deliverable color digital files from the same system so I don’t have to carry a Nikon body in addition to the Hasselblads.Since the 907x body is likely such a small premium on the cost of the package (I can't see the back selling for much less than about $6000 standalone), I'd just buy a 907x and leave the body section in the box.
Has Hasselblad ever sold standalone digital backs? I'm curious.
Joe
It does.Question about the CFVII 50c, I assume it clears the underside of a PME90 prism finder when on a 500 series camera?
PS. I can recommend getting the Acute Matte screen for CFV (3042264).It does.
Yep, I had one with my CFV50C. B&H stocks them so I will likely order another one once I get a CFV back again. Worst case I can take one of my 8 Acute Matte screens and use a sharpie. Thanks for confirming the clearance of the PME 90, it's essential for use with the back for vertical shots.PS. I can recommend getting the Acute Matte screen for CFV (3042264).
You're welcome! For sure this is the way to go for vertical.Yep, I had one with my CFV50C. B&H stocks them so I will likely order another one once I get a CFV back again. Worst case I can take one of my 8 Acute Matte screens and use a sharpie. Thanks for confirming the clearance of the PME 90, it's essential for use with the back for vertical shots.
Since I don't have this finder and likely won't in the future, this is just a theoretical conjecture ... Do you think there's enough material in the PME90 housing to be able to file or mill it out for a little more clearance so that it will not contact the back's release lever?...
One caveat though, the PME back ejection system forces a slight push on the CFV lever. This creates some play as the prongs of the body are angled to always engage the back fully when the lever is not pushed – in my case. I am concerned that because of this the CFV might not be perfectly flush against the 500C/M body in this setup. Nitpicking perhaps. Could be an issue for closeups. ...
Yes, quite possibly a solution, Godfrey. But I'd recommend anybody to check on their particular setup that the back sits flush before using it. It for sure works by design and the dimensions are all compatible, just be aware that tolerances on the ejection mechanism are small.Since I don't have this finder and likely won't in the future, this is just a theoretical conjecture ... Do you think there's enough material in the PME90 housing to be able to file or mill it out for a little more clearance so that it will not contact the back's release lever?
I looked at the mechanism on the finder, it might have to be taken apart to retool it, I won’t know until I try it all out. I am also thinking I could order a spare part and rework that and keep the stock one for resale reasons.Yes, quite possibly a solution, Godfrey. But I'd recommend anybody to check on their particular setup that the back sits flush before using it. It for sure works by design and the dimensions are all compatible, just be aware that tolerances on the ejection mechanism are small.
