L1001680.jpg by Carl Schofield, on FlickrTrying again.framed print on canvas of some winter ferns around base of a hemlock tree in Buttermilk gorge. Print was shot using Leica M10M with Contax G 45/2 Carl Zeiss planar in M mount.
Test shot using the Visoflex on the M10M. I had it set to record GPS and the data was in exif and displayed in LR, but the uploaded jpg did not retain the coordinates or Flickr stripped them.
M10M Voigtlander 50/2 APO Lanthar
Fixed, had to manually drag image to map in Flickr. Never had this issue before.
@scho - I can only see your image as a sequence of letters and numbers.jpg !!
Several of my images have also obviously been deleted -
folders containing entire year collections are no longer visible?
L1001700.jpg by Carl Schofield, on Flickr
L1001708-Pano.jpg by Carl Schofield, on FlickrI see no photo Carl, only filename ending with .jpgAnother old orphaned lens, but still very nice. This is the Pentax 67 55/4 in a PT67-EOS Vertex adapter mounted to the M10M with the Canon EF - LM adapter. Bulky affair that is tripod mounted. Shoot 4 images rotating the camera/vertex adapter between each shot. Stitched with LR photo merge function. Final image is approximately 1:1 100 MP.
Yes, I have been using Flickr as my online image storage area for posting linked images in various forums. My routine has been to select an image within my Flickr photo stream copy the url for the photo and then simply paste it into the forum thread where I wanted it displayed. This worked for several years, but recently Flickr has been requiring a "feedback" to Flickr in the process. The new requirement is to use the Flickr "embed" process which unfortunately conflicts with the GetDPI system. I am currently trying out workarounds but if that fails then i will abandon Flickr and look for another hosting site. Note that I work from a Macintosh computer and Adobe Lightroom. Any recommended solutions would be welcome.I think both Carl and Godfrey use Flickr, but it's only Carl's that at times won't show up.
Carl, did you check Godfrey’s Flickr links ? They seem slightly different.Mm, Godfrey apparently also uses Flickr to post his pictures, but his links are different "https ://flic.kr/p/2rNTh2J]https://live.staticflickr.com/65535/55008175196_60237c6a8e_h. jpg"
Note: mind the two spaces I put in; one after https and one before jpg
