diggles
Since LCC frames are used frequently with tech cam lenses I decided to give it a try with the Canon TSE lenses on the GFX.
Here are my first shot with the TSE 24 ii and no perspective adjustments…I did not shoot an LCC with this one.
Here is the TSE 24 ii with 5mm of vertical shift and the corresponding LCC. There is some light fall off, but not much. Overall is it pretty clean.
The vertical shift on this image was set to the 12mm max on the lens. You'll see the LCC is showing some vignetting in the corners. The third shot shows how the image cleaned up by applying LCC correction in Capture One.
On this image the lens is rotated 30° with a 7mm shift. Not exactly sure how the numbers work out, but something like 7mm vertical and 7mm horizontal. You see the vignette is becoming dense in the bottom left corner. Applying the LCC cleaned this one up nicely as well.
