Hasselblad C-lenses: Using the timer with digital back
anyone
Hi there,
I have one question: is it possible to use the timer of the Hasselblad C-lenses with a phase one digital back?
So far, I couldn't get it to work. I both tried the 0 latency as well as normal mode, and a wake-up-cable and regular sync cable.
Am I overlooking something?
Thank you!
DaveS
Hi there,
Thank you!
Hi, I have used the self timer of C lenses on a Hasselblad X1D by:
1 - Setting the correct manual exposure on the lens. (Both Aperture and Speed)
2 - And the correct ISO on the camera, then on the camera do a bulb or long exposure setting. (Longer than the self timer setting)
3 -Then start the self timer and then start the camera exposure
This way the camera is exposing darkness, and the correct exposure happens when the lens fires.
This should work with any camera combo, but the big Hassle (pun intended) with this method is you need trigger the lens self timer firing off camera and mount the lens prefocused before firing the camera.
whew
Dave
anyone
Hi Dave,
thanks a lot! That might work in the P1 case only when the back is removed while the camera is triggered. I'll try it out. Of course removing the digital back often is a pain...
