Not so good news: the problem wasn't fixed. Back to Sweden. This time with a video-documentation of the issue...
That is so frustrating. I hope the video evidence finally points them in the right direction and they fix it properly this time.Not so good news: the problem wasn't fixed. Back to Sweden. This time with a video-documentation of the issue...
That’s heartbreaking.Not so good news: the problem wasn't fixed. Back to Sweden. This time with a video-documentation of the issue...
Did the repair come back with any documentation, like “no fault found”, “problem ‘x’ found and repaired”, etc?
I hadn't experienced this but just tried it on my 907x to be sure and confirmed that my copy doesn't show the behavior you describe. I hope you get your situation resolved quickly and to your satisfaction. The design requiring you to hold down the little button with your thumb while trying to rotate the slippery little ring with one finger is kludgy enough as it is!Thank you for crossing fingers! While the defect itself is minor, I want to have it fixed while the 907x still has some warranty left.
Yes: they did not find any fault in the dial.
It's weird, but clearly reproducable: immediately after I turn on the 907x with a lens attached and want to change the EV compensation to negative, it first adjusts +0.3 into positive before it works as intended. Once the 907x is running for a while, the error doesn't occur. Maybe someone with a 907x and CFV100c could try it out whether you have the same issue or not?
So true! I also tried with my 907X 50c and the wheel for EV compensation also works as expected.The design requiring you to hold down the little button with your thumb while trying to rotate the slippery little ring with one finger is kludgy enough as it is!
Got my camera back. This time with a fancy letter that it got all checked and the signature of the technician. I was reliefed and tried it out: same issue. Back to Sweden.....
Holy crap. That is so frustrating!
Apropos of nothing, it reminds me of the time I bought a fancy Italian stove top espresso maker and the filter didn't fit. I complained to the store, and the store contacted the factory. The factory sent me a short video of a guy inserting the filter. He must have thought I was a complete idiot. I sent him a video of me not being able to insert the filter because they hadn't machined it properly! The replacement coffee maker arrived soon thereafter...
I hope "three times is the charm" works out for you.![]()
I think this time you'd better go yourself together with the camera. To live demo the issue. But do demo it in slow-motion, they could not get it.
Good luck - I can’t imagine how disheartening this is.It is! We did send a video last time. I also tried to really carefully explain the phenomenon. They did change a few parts… but still, no result.
True, since the video we sent last time was not enough. I start to miss my P1 back…
Just for the record: my 907x CFV100c is still in Sweden. Now we have end of April. That's a whopping 5 month odyssey.
If they can’t fix it they have to change the item or they give you the money back. There is a term in German „Wandlung“. Which means you are going back to the point before purchasing.Just for the record: my 907x CFV100c is still in Sweden. Now we have end of April. That's a whopping 5 month odyssey.
Depends if it still under warranty. Or at least when it was sent in.If they can’t fix it they have to change the item or they give you the money back. There is a term in German „Wandlung“. Which means you are going back to the point before purchasing.
If they are smart they will make you an offer for an upgrade to the 100c for a very good price. Try it.
Right. But I would try it anyway.Depends if it still under warranty. Or at least when it was sent in.
