As luck would have it, my XCD 45p lens beat my 907x, and since I don't own either x1d camera, I'm left fondling this wonderful little lens without being able to mount it on a body.
However, I did notice one quirk—I realize the 45p has "mechanically coupled manual focusing" as a feature. Reading that, I expected the lens's focusing ring to cause the focusing elements to move in and out when I rotated the ring. And they do, sometimes. But other times, the ring simply rotates, with a light vibration feel suggesting that a clutch is slipping somewhere. If I orient the lens to face the ground, then when I rotate the focusing ring in the direction that extends the optical elements, gravity-assisted, the lens will usually extend that way. And if the lens is pointing to the ceiling, then I can rotate the focusing ring in the direction that retracts the optics, once again assisted by gravity.
Just casually turning the focusing ring without orienting the lens up or down, however, just causes the focusing ring to slip, much like a focus-by-wire lens.
Is this normal behavior for the XCD 45p? I tried to search the forum but the search function apparently isn't working for me.
Thank you!
Thank you!
