  • HAPPY THANKSGIVING TO ALL OUR AMERICAN FRIENDS!
How about more and more fun with Canon...
scho
First visitor this fall to my feeder. Canon EOS R (FS) with no filtration. Sharpened in Topaz Sharpen AI using stabilize mode to remove some "bird twitch".
scho
A few shots taken with the Canon EOS R and 85/1.8 EF at the Ithaca Apple festival on the commons.
scho
Understated pastel fall color with the Canon EOS R (FS) on the Cambo Actus with 60mm f/4 Actar lens and no CC filter color correction. Six shots stitched with PhotoMerge in Lightroom.
scho
Just playing around with kitchen counter top still life focus stacks. These were done using the EOS R and RF35/1.8 Macro with Arsenal automated stacking 5-6 shots each. Getting better, but the major limitation is still only have 6 mp jpeg output of stacked files. They say that the team is finalizing high res DNG file output, but when is the big unknown.
scho
Re-worked an image taken last summer to make a large print. Lansing, NY hay fields taken with the Canon EOS R (FS) with RF35/1.8 and Kolari IRChrome filter. Printed image is 17x30 inches on Hahnemuhle Metallic Photo Rag using Epson P800 and ImagePrint Black.
All shot last year with an EOS R
An old railroad-related building in Peoria, Arizona.. I began 2019 with a Sony a7R3 system, went thru this EOS R and a Panasonic S1R (too heavy for this old man with a somewhat-handicapped right arm), and then bought another Sony, this time an a7R4.. And finally after FOUR a7Rns, I figured out that I still don't like 'em much.. I'm now waiting for the EOS hi-rez, hi-DR body with IBIS and dual card slots; next month, Canon?? Have already started gathering parts such as the drop-in-circ-pol EF-to-RF adapter (for $199 last month instead of $299).
I initially planned to buy the newish RF15-35/2.8 and the RF24-105, but now--EDIT--have purchased a Zeiss Milvus 18mm/2.8--CLOSE EDIT--to add to my TS-E50, Otus 55/1.4 (EF), and old, lite-weight, excellent EF 70-200/L/USM with 1.4X-III, all for use on that circ-pol adapter.. Ought to be a good combo with the RF24-105.
Will add more pics as I find them.
scho
House bound today so played around a bit with the EOS R and Tamron SP 90/2.8 Di Macro lens. Subject was a little Cyclamen houseplant and camera mounted to tripod with Arsenal remote on top. Used the Arsenal app on my iPhone to control the shooting. Used focus stack mode and let Arsenal do its thing, taking and stacking 6 shots. Although I was shooting in raw mode Arsenal still cannot export a stack in high res DNG format. I exported the stack as a jpeg via email and then copied the 6 raw images that Arsenal used to create the stack from the camera to my computer where I used them to create a stack in raw mode via Zerene stacking software.
Arsenal stack exported as jpeg
Zerene stack from raws
scho
I installed a new Astronomic L-2 UV-IR block clip filter in my EOS R (FS) and then did a custom white balance using a white wall image. Seems to be OK after a few test shots indoors and out using the custom white balance and no lens filters. I was hoping they would have an OWB clip filter but this filter seems to do the job just fine. These shots were taken with the R 24-105. Only issue was unable to use the 35 R because of protruding rear element.
OOC focus stack with Arsenal
scho
Steamboat Landing on Cayuga Inlet at the Ithaca Farmers Market. Canon EOS R with 24-105 RF and Arsenal Remote. 5 shot focus stack from Arsenal OOC 6 MP jpeg file and raw composite in Zerene stacker
OOC jpeg
Zerene focus stack from raw image files
scho
Same comparison as above inside the Farmers Market. Upscaled (Topaz A.I. Gigapixel) the OOC 6 MP jpeg file to the same pixel dimensions as the raw file stack for comparison.
From OOC jpeg
From Zerene focus stack using original raw files
A few shot at the Early Days Engine & Tractor Assoc. annual show in Glendale, AZ, the WE of Feb. 08-09.. 5DSR new last month with new Tamron 35-150/2.8-4/VC, which has replaced my too-short Canon 24-70/4/L/IS.
scho
Another attempt to keep busy under house confinement. Some more houseplant shots, this time using the Canon EOS R with RF 24-105, tripod mounted with Arsenal remote attached. These are 5 shot automated focus stacks using manual aperture control set for f/4 or 4.5, ISO 125. Output is still only 6 MP jpegs from the stacks but I've been batching the jpeg stacks through Topaz Gigapixel AI set to output 2x (24 MP) 16 bit Tiff files which are then exported to LR for final processing and upload to Flickr. Click for full size.
Orchid
Clivia
