That sounds most frustrating, Jeff. I've never had that problem myself; it's usually that the ring is tough to get started. It sounds as if one of the threads is damaged.Watch out on the rear retaining ring. I've got one that's stuck on the last couple threads. Will likely have to Dremel it off. I have the lens spanner above and it worked till the retaining ring decided to stop turning.
Just curious- what lens do you have? Perhaps someone else with the same lens could use the Cambo mount- it definitely has some value.Hello everyone,
I just came across a lens in Cambo tilt swing mount. However, I plan to use the lens on a non-Cambo view camera, as a result, I don't need the mount at all. So what's the best way to remove the Cambo mount? Is this kind of service expensive?
Thank you so much.
I have that spanner too. It's a piece of sh!t. The thumb wheels can't lock down tightly enough to the bars. I hope yours works better than mine. It's hard to apply strong, consistent force when the thing wants to come apart!Watch out on the rear retaining ring. I've got one that's stuck on the last couple threads. Will likely have to Dremel it off. I have the lens spanner above and it worked till the retaining ring decided to stop turning.
Please let me know for what lens the mount is. I may be interested in buying it.Hello everyone,
Thank you so much.
