Hello All,
I own a Leaf Aptus 75 using it with Maiya RZ67 proII. For more critical inspection of my focusing I found a Macbook pro 2009 for tethering the back. Leaf Capture is installed on the macbook and everything works fine.
But When I plug in the digital back with the firewire( the one that came with the back) the DB immediatelly turns on without the need of pushing the power button of the DB. Also I cannot switch of the DB by the button while the back is connected to the computer by Firewire. The only way to switch the back off is by shutting down the computer AND I don't know if this is shutting down correctly the back or if it forces it because of power outage.
I have read in another threat that Leaf Aptus 75 had an issue of damaged firewire port and/or cf card port and I dont wat to end up in that situation.
this is the thread(https://forum.luminous-landscape.com/index.php?topic=73356.0)
The thread made me hesitate plugging the DB on the MacBook which I bought only for being able to tether this DB.
So Does anyone have experience of using these old DBs tethered and if it is normal that the back is starting up immediatelly when plugged on the computer?
And what is the safe way to switch off the DB while it is connected to the computer?
I have also tried to disconect the camera from leaf capture but still no response from the power switch button
I know that the back is old and some people may suggest that I have to move on to a newer model but this is not the case. I bought this db last year ant the actuations count was 50. Yes only 50. and now it is about 400 actuations.
thank you for your time
