Leica S007 Using Hasselblad HC lenses with Adaptor
It has been a few years, but yes, I did adapt my Hasselblad lenses to the S007. I still have the camera and the lenses if you’re trying to figure out anything particular. I love shooting with the Leica!
I regularly use the HCD 28mm. Works like a charm. About the same size and weight as the S24mm, maybe bigger in diameter. On the other hand, I have an HCD 50-110mm that I hesitate to use without a tripod (1650g without the adapter).
I feel I have the Best of Both worlds. To Keep the S007 with the S-H adaptor and still use the Hassy H5D-50 .
I am waiting on the adaptor to see the IQ and Rendering between Both Cameras. TY for sharing your thoughts
I took some photos with Both the Leica S007 and the Hassy H5D-50 with Both HC lenses. I honestly can say I cant see that much difference between them. The sharpness, Color rendering.
Is this Possible ? I havent tried Portraits yet Just outdoor scenes at the same time and same Settings
I have taken the same still life with the S3, Hasselblad 907x/CFV100C and Hy6/Leaf AFi II 7. Same lighting (strobe), same ISO. The CCD was a bit warmer and softer, otherwise hard to find much of a difference. Of course all three used excellent lenses designed for each system.
I recently added an HC 150 and 210. They work fine with the 006 and the H adapter. I also have a 907x and an H adapter and the AF does not work with those lenses because they are older, not orange dot/square and the firmware cannot be updated. The 150 does not work at all, the camera cannot control the shutter and diaphragm.
