M10 Monochrome
mkerouac
Thank you for the post Keith. This is helpful. I have never let LR make decisions for me before, but this may be an easy solution. I did notice that I had to set negative exposure comp. I have a White House and a white dog, so photos taken in my yard, revealed that the sensor would easily blow out highlights if I wasn't careful.
Geoff
Am somewhat puzzled by the posts re the need for extensive post-processing of the .dng's. Have had my M10M since early Feb and was quickly able to settle on a methodology that is certainly not time-consuming (patience is not one of my strong points...). On the camera I usually have exp comp set to -0.3, sometimes -0.7. Import into LR Classic and click on 'Auto' at which LR applies a custom tone curve, then go into the Development panel for a play with the sliders. Sometimes I might reduce contrast then boost clarity depending on the subject. Rarely use the dehaze slider. Example dev panel and result below. On my Flickr page is my M10M album with over 250 photos covering a wide variety of subjects and conditions. All in all I thoroughly enjoy the camera and results - such that my M7 and 503CX have lain unused since it arrived.
Example taken with 21mm Super Elmar-M f3.4 + orange filter.
View attachment 176854View attachment 176856
And your work is stunning. Really lovely, and inspiring. The M10M looks like medium format in these - quite discernably. Oddly, find it hard to get that look from the MM1, except in particular light. It may be the DR of the M10M is just pulling in the ends of spectrum.
tcdeveau
Yeah the M Monochrom's in general are subject to blown highlights from my understanding. I have mine set for -0.3 to -0.7 exposure comp as well. I should look into the settings of my camera. I purchased mine used from a fellow forum member, so the camera may not be operating with straight-from-the-factory settings.
All of the pictures I've posted in the "Fun with...." thread have all more or less been SOOC after import/export from LR. I found I haven't had to play with the settings much at all, but I did notice LR appears to apply some sort of tonal "S" curve upon import (with blacks/shadows lowered and whites/highlights raised), so there could be some sort of "Auto" thing going. Never looked into it because I liked what I saw, and the embedded preview in LR was similar to what I was seeing on the back of the camera.
I've also been shooting only mundane scenes around my house and I haven't gotten out with it at all. My processing for my current subject matter (which is basically no processing) probably wouldn't be the same as a landscape scene. There's of course also the issue of my aesthetic tastes may not be the same as another.
Thanks Keith for sharing your screenshot settings as well!
I've been enjoying the camera quite a bit. Told my wife the other day I don't remember the last time I've had this much fun with a camera.
glenerrolrd
The m10m files are “flat” a linear response curve . This offers the optimum file for post processing because you have retained as much information as possible . i use the preset developed by David Farkas ..free at RedDot Forum . Using the preset ..the m10M file is as good as I can produce for B&W .
Using color files (say M10) ....I could get best results using Capture One or LR followed by Silver Effects Pro to simulate Fuji Acros plus a little more contrast .
