I’m casting around for guidance so this echoes an inquiry I put up yesterday on the Leica Forum (apologies to any of you who follow both). I’ve been using Leica M’s since the M8 for landscape work as, early on, Leica was the only maker offering full frame IQ in a relatively light and compact package. I recently acquired an M10 Monochrom and am very impressed by its image quality. I do have one complaint, however. All the M’s I’ve used previously had reasonably convenient settings for exposure bracketing. In the M10 generation this critical function for landscape work has been relegated to the drive mode menu item. I could live with that except that it appears the camera does not remember its drive mode setting and each time I turn it off and on again (which you need to do often to conserve the reduced battery life) I find the drive mode has reverted to single exposure. Worse, even after you select exposure bracketing, there appears to be no way to combine that with the shutter delay function. So I have had to keep the shutter button mashed down manually through the three or five shot sequence (thereby ensuring camera shake even on a tripod and ruining any potential exposure blending in post).
This makes absolutely no sense, especially since adding this function would entail such a minor firmware fix, so I am wondering if I am just missing something in the manual or settings, or if my camera is somehow defective. I’ve since learned that the SL apparently also cannot combine exposure bracketing with shutter delay and am having trouble imagining why Leica would write off landscape and architecture photographers who would obviously want this capability. Any advice welcome (especially if it might be a problem only with my new camera).
