M11 Images
drunkenspyder
Not sure whether to post in the Digital M or the M11 thread. So, choosing the more specific. A proof of concept of an interpretation of the IBM & Trump towers along Chicago's Riverwalk.
M11 | Voigt Heliar 15 | f/16 | 24s | ISO 64 | 5-image stitch
algrove
If anyone wants a new LEICA M11 silver version, I was just informed SE Camera has one in stock. (919)890-4484. I have no affiliation with them other than as a customer.
KeithDM
Poole's Twin Sails Bridge (a double leaved bascule bridge). I knew where the bridge is located but had not previously seen it. Stumbled across a handy viewing point yesterday, was standing there pondering whether or not to change lens (a prime 50mm on the camera) when it started to open! So 50mm it was.
1) In progress. 2) Almost there. 3) The reason why...
M11, 50mm Noctilux f1.2
drevil
Staff member
View attachment 198054View attachment 198055View attachment 198056
just watched a video of that bridge, any advantage with this design rather the traditional design?
KeithDM
Well, according the the local tourist board blurb:-
Its unique triangular-shaped lifting leaves reflect Poole's proud maritime and industrial heritage. When the bridge is up, the two lifting leaves symbolise the sails of a yacht and offer different views from every position along the quayside, from a sailing symbol to the spire of a cathedral.
Given its long gestation period, closures and erratic reliability the locals have other descriptions, "white elephant" being one of the kinder choices of words...
Chris C
................. proof of concept..............
M11 | Voigt Heliar 15 | f/16 | 24s | ISO 64 | 2-image stitch
Hello – I couldn't remember where I'd seen this excellent picture and I've scoured the forum to return to it. The picture has been bugging me. I have no sense of a 15mm field of view, but I make the [safe?] assumption that a diverging and a converging image are corrected and joined. I have candidate methods for the joining, with duplicate layering and mask erasing, but I'm uncertain of how you did it. Are you willing to reveal the work sequence you used to determine your smooth join?
.............. Chris
drunkenspyder
Sure thing Chris; thanks for the good words, but sorry it's been bugging you! However, I have a feeling your workflow is significantly more sophisticated than mine, and you may be disappointed. ;)One thing worth knowing is that I shot the base images from the 19th floor of our hotel across the street from the IBM Tower. I think that was something of an advantage for this composition. There are five base images, each of which consists of three bracketed exposures. Portrait orientation. HDR combination was done in Capture One with alignment only, no adjustments. Each of the five images were then adjusted and random RGB values were checked to make sure that all five images appeared to be different pieces of one big image. Then, each image was adjusted in C1 for keystone as much as possible, and I checked the pixel dimensions of the two buildings and selected elements. Even with all that, C1 did not want to stitch the panorama. It's funny, sometimes it does a fantastic job without breaking a sweat, but not this time. So, I did the panorama in PS [I miss Autopano Giga].It took several different efforts to get the best result with what appeared to my eye to be the least amount of distortion possible. IIRC, I found the most satisfactory outcome with the Reposition Layout, but still had to do some manual mask adjustments. I layered another piece of a sixth image to address some stitching artifacts in shadows, but I'll need to do that more carefully when I work on the final image. As I mentioned, this was just a proof of concept done while I was still on the road. I like the concept, but it needs more work to get to how I want it to feel. Hope this was helpful; if not, ask away. Cheers!🍻
Chris C
Sure thing Chris;..... I have a feeling your workflow is significantly more sophisticated than mine, and you may be disappointed. ;).... I shot the base images from the 19th floor ...There are five base images,.... Portrait orientation. HDR combination was done in Capture One with alignment only, ... each image was adjusted in C1 for keystone ...... checked the pixel dimensions of the two buildings....C1 did not want to stitch the panorama.... I did the panorama in PS.....
Thank you very much for your speedy and generous reply; this unsophisticated peasant is very grateful. I'm sure a largish print would look handsome and compelling – your concept is proven admirably, congratulations.
............. Chris
