tribal-warrior
I have been reading a little bit about the 6 x 8 back for the Mamiya RB67 lately. And I was a little dismayed when I read that the 6 x 8 film size could only be utilised when the back is set to the vertical orientation. That's a huge limitation in my book. I mean just think of the potential you could have if you were able to shoot 6 x 8 horizontally with an RB67.
Then I got thinking......suppose you did set the 6 x 8 back in the vertical position and then rotated the whole camera sideways so that the RB67 was in a horizontal position on a tripod. Would you then have a horizontal 6 x 8cm frame? Obviously, you would not normally rotate this camera because it has a rotating back to switch between horizontal and vertical orientations. Though in this case, it may be the only way that you could shoot 6 x 8 horizontally.
I'm still not 100% sure that this would work though.
