jecxz
Hi Guys,
I could use some help; I have a particular way of working and need the camera to work my way. I have finished reading the manual and I cannot get the setup answers that I need. Here is how I want the camera to operate and thank you in advance for your setup guidance.
1. Front dial for Aperture only (I want the lens aperture to be set by the dial, not by the lens ring). I found the menu option to set the dial to Aperture however it doesn't always work and the menu option shows 3 assignments to the single dial - huh? I need it to be in A priority, so when I set the aperture (turn the dial), the camera sets the shutter.
2. Rear dial for exposure compensation - I do not want to have to press the +/- button every time. I found the menu option to only press it once, not hold it down, but I do not want to have to press it at all. When I turn the rear dial is should shift the shutter speed only.
3. What lens setting do I need the ring to be in for the above C or A? I assume A stands for Auto? C is what, Continuous? Country? Cow? Confused?
This camera is very nice, however, I am confused enough, please help me set to the above because right now it's a total brick to me; I am an artist, not a technician. I need to simplify this bad-boy so it works without requiring me to think like an engineer. I promise I will have more questions! Again, thank you in advance.
Kind regards,
Derek
Kind regards,
Derek
