espelancer
I am trying to learn calculation based tilt and focus. I have been using GG, but I feel I am getting old and cannot nail it down with a DB, so I am trying to learn calculation based. Here is what I learnt and I need some help.
I have a 60mp Phase one DB and 45mm lens. With those, I calculated the hyper focus distance as approximately 50 feet or 15m. With that the object at distance (beyond 15m) look sharp without tilt.
looking at the snapi app, it tells me that if my lens axis is 2ft above the ground, I should be able to get the ground as well as the distant object sharp with 4.2 degree of tilt without refocus (I used back axis tilt and moved the camera body to keep the back vertical). During the test, the ground does get clearer, but the distant object gets much blurry.
I wonder is my calculation wrong, or my operation?
Basically, I am trying to learn whether with hyper focus, I can forget about focusing when using tilt below 5 degrees.
