So ... after finding some time ... here is the comaprison of the 2 different grips available.
I got an used one for 50€ second hand ... want to work with the H3D22 on weddings, at least a second battery is a must have ... would love to add a second CF slot too :facesmack:
Left is the newer one, right side the older version, although it seems there have been some updates, see connector to the small board.
The new version is much easier to open, just use some smartphone tools or a guitar pick, make sure it's from your favourite band, although I think it will open up even with a less rocky background
As you can also see, the new one is a tad bigger (somehow the lines were messed up when downsizing...sorry for that).
So you can only update the inner parts by using 18650 cells for the new one and updating the old one to 18650 cells will be a problem, although electronics should handle it.
BE AWARE THERE ARE ELECTRONICS ALSO ON THE BATTERY PACK UNDERNEATH THE SHRINK WRAPPING! YOU MUST MAKE SURE THE NEW BATTERY HAS THIS ELECTRONICS OR YOU JUST SWAP IT, THIS IS A SO CALLED BALANCER BOARD SO THE 2 CELLS STAY ON A SAME CHARGING LEVEL!
The 1850mAh battery I received is still ok, I have tested it separately with my RC loader and balanced the 2 cells, let's see how long that will feed the sensor of the H3D.
If this one ever dies, I'll try to update it with higher capacity cells, the maximum size for the cell is 50x36x22mm ... maybe a millimeter more in width will fit, height should not be more than 50mm ...
Also the protection cover will not fit the other batteries, the small nipple is at a different position, changed from inside to outside... if you ever take into conmsideration to buy a cover only, make sure to get the right one.
NEW version uses 18650 Li-Ion round cells, I'd say you should go with Samsung or Sanyo cells 3400-3600mAh capacity
OLD version uses the rectangle shape Li-Ion, check with yourt local RC specialist or google, you need to get 2s Li-Ion cells, mine is filled with an Celltech - Celltech Sverige AB21HA,7.4V 1950mAh 14.43Wh
Place for pictures .. why can't I upload files?? I downsized them and tried to upload ...
See FlickR
DSC_0003 by Mike La Bruna, auf Flickr
DSC_0004 by Mike La Bruna, auf Flickr
DSC_0005 by Mike La Bruna, auf Flickr
DSC_0006 by Mike La Bruna, auf Flickr
DSC_0007 by Mike La Bruna, auf Flickr
DSC_0008 by Mike La Bruna, auf Flickr
DSC_0009 by Mike La Bruna, auf Flickr
See FlickR
