Great news! That was much faster than my delivery. Congratulations. I will be surprised if you are not thrilled with the images.
One tool I suggest you find is a piece of black ABS you can use to cover the hood for black reference frames. The hood Alpa supplies is great and, as near as I can tell, light tight. You can just hold the ABS tight against the end of the hood instead of removing it and covering the lens with the lens cap.
Dave
Hi Dave, I doubt you'll be surprised based on first impressions
Given the 138's price point, for me to say "no regrets buying this lens after reviewing my first batch of test images", is essentially saying I'm thrilled. I can be pretty obtuse at times. Thanks for the tip re: capturing black reference using black ABS. Makes a lot of sense. I may build on your suggestion and glue a thin sheet of rubber to surfaces to help ensure no light leakage.
Let us know your impressions on sharpness shifted and centered on your Alpa
Will do Paul, I shot shifted yesterday but was short on time. I like what I'm seeing so far, but I need more time with the lens. It'll be a week or two before I can get a complete series. I'll be happy to share images if interest.
Interesting focal-length choices for a two-lens kit. I wonder, why didn't you get the 32mm instead of the 40mm? This way you would had both ends of the Digaron-(S)W line covered.
Dude, I considered the 32 and I opted for the 40 instead for several reasons. 1) It's lighter and more compact than the 32, 2) I reach for < 24mm (35mm equivalent) less than 20% of time, so I'd be overreliant on cropping with the 32 as part of a two-lens kit (compensating for fl with my feet is often not an option), 3) I can take advantage of the tech cam's movements to easily shoot to stitch when wanting a larger fov (i.e, put the tech cam to work for me w/ understanding that there are limitations and caveats), 4) it keeps a slot open to get the 23 if/when I decide to add a third lens, and 5) the 40 came highly recommend for it's optical performance by a few persons whose opinions I trust.
I also have a concern about the 32's "gooseneck" from the perspective of how easily the lens might get damaged (although, I don't have any evidence to support this being an issue), and it doesn't hurt that the 40 is less expensive. However, neither of these were dominant decision factors, which is why I'm calling them out separately.
