It seems the story of my Mamiya N 43mm wasn't quite done. In my post from last Saturday, I was quite pleased about where things landed. Things got busy so I didn't have a chance to test it out at longer distances for a few days. When I finally had some time, I took it upstairs to a 2nd story window that looks out over my hill slope backyard and the fence that runs across the top. It's a convenient test target for checking alignment, field curvature, etc. because the fence line is parallel to the back of my house.
It's possible when judging cell spacing against a wall of Siemens Stars to overlook a bit of softness on one side relative to the other, but it's a lot harder against a real world scene like this. When I looked at the images I made on the computer, there was no denying that the right side was soft, and that it never became acceptably sharp with smaller apertures.
There are a lot of links in the chain that could have been the problem. Starting with the lens, there's incorrect shimming, or perhaps an unfixable problem like damage to the housing that puts the cells out of parallel. The lens mounts to the view camera with a custom lens board I built, and that board might have an alignment issue. View cameras do go out of alignment with time and wear, so a swung front standard was possible. The GFX camera mount itself might even be out of parallel.
All the non-lens links were easy to rule out. None of my other lenses showed soft right sides on the F-Universalis, which means the standard is not out of alignment. My Mamiya N 65mm shares the same board, and it's flawless from left to right -- so there's nothing wrong with the lens board. Unfortunately, that left only the lens itself as the culprit.
Long story short, I re-checked the shimming and made some small adjustments that created meaningful improvements. But even after all this re-calibration, the right side was still bad. I almost gave up at this point. It's not like the lens was unusable. I used it extensively in 2023 with a shim spacing that wasn't quite as good as the one I have now. None of the scenes I shot in 2023 were flat targets, so I was using movements all the time to adjust the plane of focus, and that masked the softness on the right that would have been apparent had I been shooting brick walls.
Thankfully, I remembered one more trick I hadn't tried. One of the features of the F-Universalis design that I prize is the ability to rotate the square lens board to any of four possible orientations. Sometimes I want the scale on the lens up, but mostly I want it on the left side from behind so I can peek around the camera and see the aperture position easily when the camera is at head height. All of my Mamiya 43mm adjustments had the lens board mounted with the lens scale "sideways", on the left side. However, I remembered that I have had lenses that I could use only in one orientation because only that orientation gave good results. When I mounted the lens board so that the aperture scale on the Mamiya 43mm was "up" instead of sideways, the softness disappeared.
This is a 100% view of the right-hand side of the fence line at f/4.5 (wide open). At left, the lens scale is "up", and at right the lens scale is on the left side (from behind the camera).
There's no such thing as a free lunch in this game, so of course I wondered "where did the softness go?" Logically, if it is on the right side of the image when the lens scale is on the left side, then rotating the lens 90 degrees clockwise should have put the softness on the bottom of the frame. The mystery -- and the good news -- is that the softness seems to have disappeared entirely. I checked against my Siemens Star wall, and the image is now equally sharp everywhere. It's not soft on the bottom.
As I mentioned earlier in the post, the image quality "chain" has a lot of links in it with my kind of setup. All I can say is that the simple action of orienting the correctly shimmed lens on the camera the "correct" way seems to have meshed with all the other links in the chain to produce the best possible result. It's bizarre, but I'll take it!
Rob, that's an excellent account of the issue and a great result.
In the majority of forum discussions, any anomalous softness is immediately attributed to the lens itself. Few people suspect that the real culprit may well be the mounting hardware.
Your account shows that checking the dimensions, flatness and alignment of the mounting hardware should be near the top of the list.
