I've tried asking this question in the MF forum, but I got MF answers.
I am trying to find a setup which will not be too expensive but will give me good results for close up (macro) with a digital sensor.
I would like to improve DOF sharpness mostly, for objects around 1"-1'.
Now I am using Canon 1Ds3 at f/22 and of course I would like to see something better, otherwise what's the point.
The main problem is diffraction.
I've tried Mamiya ZD with Mamiya 120mm Digital, and I saw good results at f/32.
Other non digital lenses from Mamiya Zeiss and Schneider with not good results.
My conclusion was that I need a digital lens.
So I found these LF lenses:
- Schneider 120mm f/5.6 Apo Digitar M
- Rodenstock 120mm f/5.6 Apo-Macro-Sironar digital
Rodenstock literature recommends movements to get DOF sharpness rather then closed aperture.
So my questions are:
- Assuming I have the digital back and lens, what would be a cheap way to connect them? It seems I need a sliding back adapter to focus? I found a solution for $4500 (Horseman LD) or a sliding back adapter for $2500 with a used Linhof for $500. Is this right?
- Will the lenses I mentioned above give me a result much better than Canon or Mamiya? Is this worth the trouble for this specific application?
