Results 1 to 7 of 7
Thread: Bellows Factor Angle Finder Kit
    58
    While talking to one of my buddies in regard to Large format he told me about a Bellows Factor Angle Finder Kit. I was wondering if anyone here experienced working with Large Format has used one? Remembers the brand name they used? and might possibly know if they are still available?
    Thanks,
    Jason
    Mar 2010
    29
    Re: Bellows Factor Angle Finder Kit
    I've had a Quick Stick for years (from visual departures) that makes it trivial to determine bellows factor to 1/3 or 1/4 stop, if I remember right. I don't have it in front of me to be sure.
    Los Altos, CA
    10,486
    1031
    Perhaps he was referring to the Rodenstock DoF Calculator? Lots of useful tools on it: http://www.bhphotovideo.com/c/produc...ck_260700.html
    home: www.getdpi.com
    58
    Jack, I did see that but that is not what I am referring to. What I was mentioning is what was called an E Z View Bellows factor and Angle finder kit. It consists of a ruler that works in tandem with a dial type angle finder device.
    Here are the instructions for it:
    "To figure bellows factor for view cameras, place the angle finder or the chip next to the product to be photographed, line up the arrow on the bellows factor scale with the image of the angle finder chip on the groundglass, and simply read the scale."
    Then it refers to a Picture A.
    Picture A consists of two boxes of Crayola Crayons standing on edge next to one another. The Chip or Angle finder is placed sitting flat on the box or boxes and then viewed through the ground glass where you then used the Angle Factor ruler.
    "(Pic A) The bellows factor is plus 1 1/2 stops. It gives you direct readings in 1/4, 1/2, or full f/stops up to 3 1/2 stops. In the sample photograph (A) the bellows factor was 1 1/2 stops. Therefore your initial exposure was 2 seconds at f/32, the corrected exposure is to use 6 seconds. The accuracy is great, especially for photographers doing critical transparency work."
    There is slightly more to the instructions but I think this gives you an idea of the tool. Apparently this tool assists the photographer in obtaining consistent accurate readings when calculating the bellows factor and angle.
    I was just wondering if there were any experienced photographers that might have used this tool.
    Jason
    Los Altos, CA
    10,486
    1031
    Pretty sure that's the quick stick mentioned above. I still have one laying around somewhere too. This is a version at Calumet. IIRC, the one I have has more "stuff" on it: http://www.calumetphoto.com/item/CC9201/
    58
    Jack that is kind of it but its missing the angle finder. I did call them. I will keep looking and hopefully I will find it. Calumet used to carry it about 15 years ago but only have that ruler and chip now but the chip does not have an angle finder in it.
    Jason
    Mar 2010
    29
    check out jason brunner's website, he has one you can print out that is based on the same concept, but far more cost effective.
