Results 1 to 10 of 10
Thread: Graflex XLSW + MFDB?
    May 2009
    296
    Anybody know of a (sliding?) adapter that can mount a MFDB on this beast?
    Workshop Member lance_schad's Avatar
    Phila./NY
    1,146
    19
    Re: Graflex XLSW + MFDB?
    Try Keith @ Kapture Group, I believe he has sliding backs available with the Graklok interface.
    I also think Toyo used to make one as well.
    We also sell the Mamiya/Leaf version that is just a live-view adapter (not sliding).
    Hope this helps.
    Lance
    LANCE SCHAD - Digital Transitions - Phase One,Mamiya | Leaf,Arca-Swiss,Cambo, Profoto
    direct/cell:610-496-5586 office:877-367-8537x224
    http://www.digitaltransitions.com email:[email protected]tions.com
    May 2009
    296
    thanks for these leads
    Following this up I have found out "The Kapture Group 2 position STITCHING Adapter can be mounted to just about any view camera" and one for mounting for example Hassleblad V mount digital back on Arca Swiss 6x9 is for sale here for $1,999USD (reduced from $3,369)
    So far the only Toyo adapter I can find is for mounting on Toyo 4x5 not 6x9 cameras but I may be looking in the wrong direction.
    Linhof makes a "rapid slide changer" for mounting MFDB on the LINHOF M 679cs that can be bought here for about $2000 not including the adapter plate for your particular MFDB. Silvestri also has a similar offering. Probably Arca Swiss has one too.
    That leaves the live-view adapter if your MFDB has this feature that mine does not.
    Fortunately film is still available :-)
    May 2009
    296
    Goods news is Graflex made a 4x5 XL Graflok adapter that enables this camera to take anything that goes on a Graflok 4x5 back and it is much easier to find a sliding adapter for 4x5 than 2x3 cameras :-)
    Bad news is the 4x5 XL Graflok adapter is rare as hen's teeth :-(
    back to the drawing board....
    May 2009
    447
    Probably a long shot, but you might look into whether Toyo's sliding adapters for the VX23D use a baby-Graflok fitting that would be compatible with the XLSW.
    Phila./NY
    1,146
    19
    Here is another solution for Graflock. It is very inexpensive. I do not have direct experience with it, but I do have one client who purchased one and he said build quality and pretty good and it works...
    Here
    Let us know if you go down this road...
    Lance
    May 2009
    296
    thanks lance much appreciated :-)
    Phila./NY
    1,146
    19
    Quote Originally Posted by lowep View Post
    No Problem.
    Sep 2010
    Dallas/Novosibirsk
    632
    Quote Originally Posted by lance_schad View Post
    Its a lot of FUN.... I have bought it too.
    Doesnt allow for full range of motion b/c you will catch up light from that view adapter. You would think blocking it will solve issue? (after all one might have some dark plastic to spare.. Fotodiox would be far too cheap to give you one) You will be almost right. Its still allow to light go.. UNDER it.. so you getting 6x9 at best out from it, if very careful.
    Also if you handy - you can reorient it vertically - to squeeze out a bit more from rectangular 645... hence 6x9... Of course you loose limiting bolt in corner.
    Ah and also its made to some awkward thickness specs, so in order for this back to fit on precise camera like Linhof - you will have to spend some time with dremmel...
    Of course once sold - fotodiox will not even talk to customer. I sent quite a lot emails to them. Before sale - they answered quite fast. After that - ignored me completely.
    May 2009
    296
    “Give advice; if people don't listen, let adversity teach them”
    Ethiopian Proverb
