Results 1 to 3 of 3
Thread: Different copal shutters?
    Jan 2014
    188
    Hello guys,
    could ther be different copal shutters. Both N0 and similar build year. Both looks very similar. But:
    Iif i screw in the front lens element there is a small height of 1mm. The front lens prss on that height and you could not change the time on the shutter.The lens press on that height. Could i change that height?
    Thank you.
    regards
    Mueller
    Oct 2009
    128
    5
    Re: Different copal shutters?
    The interior of shutter stayed the same, but externally a lens manufacturer could specify a different front, plastic fascia ring to keep clean on a particular lens.
    I think you may be running into a snap out fascia ring.
    But remember that shutters and lenses varied so you may not get great results by screwing your glass into a new or different shutter. It may need adjustment on a columnator.
    Rod
    Jan 2014
    188
    Hi Rod,
    Thank you for your Info.
    @all:
    I have the info, that Nikon lenses have a special copal shutter. The plates for the time and aperature could not be changed. They are printed on the housing.
    mueller
