Results 1 to 5 of 5
Thread: What is the differnce Rodenstock lenses
    Jan 2014
    188
    what is the difference between a rodenstock lens with a coloured ring at the lens Barrel (like green, silver, ...) and a lensbarrel with no ring.
    For example:
    a) Rodenstock Sironar N 180mm /5.6 with no ring
    b) Rodenstock Sironar N 180mm /5.6 with a silver ring
    Are there any technical differences? Quality? Age? Better or worse one of them? A "NoGO" for digital...
    Thank you.
    mueller
    Aug 2010
    Maryland
    475
    Re: What is the differnce Rodenstock lenses
    The colored rings are a marketing gimmick.
    Rodenstock added them after Schneider started using them.
    AFAIK, there is no difference in vintages of Rodenstock lenses.
    The re-designs changed the lens series name, e.g. going from Apo-Sironar-N to Apo-Sironar-S.
    - Leigh
    Aug 2012
    Shanghai / Miami
    552
    124
    Quote Originally Posted by Leigh View Post
    The re-designs changed the lens series name, e.g. going from Sironar-N to Sironar-S.
    - Leigh
    Not exactly - the coating changed from the N - S -- The S has better contrast.
    Phil
    Aug 2010
    Maryland
    475
    The -N and -S are different designs.
    For example...
    the IC for the Apo-Sironar N 210/5.6 is 301mm, while
    the IC for the Apo-Sironar S 210/5.6 is 316mm.
    I'm sure each lens used the best coatings available at the time of manufacture, but I doubt that's the reason for changing the letter.
    My poorly-phrased point about vintages is that I'm unaware of major changes occurring that were not accompanied by a name change.
    - Leigh
    Jan 2014
    188
    I have a lot of questions. Thank you guys for your patience... :-)
