Results 1 to 5 of 5
Thread: Technika and slideing back?
    Jan 2014
    188
    Hello Guys,
    has anybody some experience with a Linhof Technika and a sliding back for a digital back. I know there is a sliding back from Linhof but this is really bulky with its up and down rising movement. This is not a solution for me.
    Do you have same experience with a graflok adapter? My technika has a graflok interface but i dont know if this is really rigid?!?!
    Thank you.
    Best mueller
    Sep 2010
    Dallas/Novosibirsk
    632
    Re: Technika and slideing back?
    Worked fine for my Tech IV.
    Jan 2014
    188
    HI Sergei,
    what solution do you use? The linhof one or the graflok?
    Thank you. Could you show some pictures?
    mueller
    Quote Originally Posted by SergeiR View Post
    Sep 2010
    Dallas/Novosibirsk
    632
    Quote Originally Posted by mueller123 View Post
    HI Sergei,
    mueller
    i used fotodiox graflok thingy. it had to be hacked (it was configured to have longer side horizontal, which makes zero sense, as making it vertical gives you more coverage) a bit but worked in the end. I rarely use it now, prefer shooting film Its somewhere in cupboards, actually should just sell it, i guess.. If only i can find it again (moved recently).
    There are same ones on ebay. I think going rate is like 200-400$, depending on luck
    Jul 2015
    Canarias (Spain)
    3
    Hello. I just arrived here.
    Thanks to admit. I'm in Spain (Canary Islands) My English is bad, so I use a translator. I urge you to have a little patience with me.
    Most of the sliding back manufactured, are for use under 4x5 formats.
    but in the case of Linhof Technika, there is a sliding back the original Linhof, which is designed to use 4x5 size. is a very useful tool,
    I use it often for many years.
