Results 1 to 4 of 4
Thread: Lightphase sliding back. What camera?
    Apr 2017
    36
    Iíve got a Lightphase sliding back for my HD 39.
    Looking at a Sinar P or a horseman 450, will both of these work with the sliding back? Iím concerned about the tilt mechanism on the horseman.
    Appreciate any and all advice.
    May 2013
    Finland
    215
    9
    Re: Lightphase sliding back. What camera?
    Flex adaptor?
    I have a Chinese made sliding back for Graflex locking.
    But I have not investigated its use on LF because I like more to use 4x5 film or a dedicated MF camera with digital back. The common problem with digital backs on LF cameras is keeping the back and front standard parallel. This is not easy with view cameras and the cameras should be as rigid as possible and have 'inherent' good parallel back and lens board.
    May 2013
    Finland
    215
    9
    Linhof Techno is a dedicated camera so how about Linhof Technica ? Expensive for sure. I have 'thougt' of using field cameras but I doubt I could use Sinar F.
    Jun 2018
    327
    Unfortunately I do not have any comments about the FlexAdapter.
    But I do own 4x5" field cameras and the mentioned Linhof Techno. In summary, the Techno is a more rigid field camera with a fixed rear standard. All movements are geared and precise, with zero detends. Still there is concern keeping the standards parallel. Exactly this might be the main concern also using the FlexAdapter on a 4x5" camera.
    The field cameras I used so far are not in the same league as the Techno when it comes to precision. Either gears are missing, or they are too unprecise. A lot of pro photographers changed from Sinar to a Linhof 679 system for increased precsion for digital use.
    On the other hand, others are happy using digital back adapters for their LF cameras (Darr for example). I decided to skip this part as I do enjoy to use my gear for 4x5" film, but am afraid I wouldn't have the same amount of joy when it comes to my digital back.
