Results 1 to 3 of 3
Thread: Pocketwizard Plus II - battery problem?
    Aug 2010
    Maryland
    475
    Thumbs down Pocketwizard Plus II - battery problem?
    I've seen references to a "melt-down" problem associated with drained batteries, but haven't found a real description of it.
    Can someone explain what's happening and the circumstances under which it occurs, so I can hopefully avoid it?
    TIA
    - Leigh
    Aug 2008
    Carmel/Tucson
    2,355
    Re: Pocketwizard Plus II - battery problem?
    I've never had any problems whatsoever with my dozen or so PW Plus/II/Transceivers---over a period of nearly ten years. I use regular Energizers or Duracells. If you aren't using a device for extended periods, you might want to remove the batteries. I've never had to with my PWs....
    Sep 2010
    Montreal
    12
    I believe it can happen with certain of their models. There is a reference here from a digi-tech:
    realworldworkflow.com/blog/?p=1003
    Roderick
    Quote Originally Posted by Leigh View Post
    TIA
    - Leigh
