Jack mentioned wanting to hear more about this subject so I thought I'd kick off a thread where we can discuss our different approaches, experiences and applications. Long post, but a lot of experiences to share
Experiences: I originally started with Elinchrom gear, mostly Mono Lights ... at the time the Octabox light modifier was "King" and that, more than anything, influenced my decision to select Elinchrom. So my initial system was built around the light modifiers as the priority.
Unfortunately, I found the lights themselves not up to the tasks I had to perform. I was constantly frustrated by different heads misfiring or dying while doing sequential images for animation or action series ... not a good thing with a set full of models and stylists. I had to keep a back-up for every light I owned and repairs where eating up my time and money.
I also came to hate the Elinchrom modifier mounting system, and carried repair kits just to keep them working. :thumbdown: But switching systems is expensive considering the investment in all the light modifiers ... the Octabox and gobo projector box alone were over $1,000. each ... which was expensive then and now. So research any buying decision throughly before jumping in the deep end.
Then I discovered that Profoto made an adapter to use Elinchrom Light Modifiers on Profoto heads :clap: So, I switched.
My apologies to Elinchrom owners with an excellent track record. My experiences on the job were what they were, and yours may well differ. As long as the mount stays the same. I'd never consider Elinchrom again.
I re-started with some Profoto Acute boxes and a few heads along with a Mono-Light 3 head kit. Due to some aggressive promotional deals, I graduated to D4-2400 boxes which is the nucleus of my studio system today. I kept a 600 and 2400 Acute box for placement options on location ... the 600 is a tiny box and a great location unit if there is power available. The strobe head inventory runs from a Dual bulb strobe head for great depth of field needs, to a stick light for tight places, to a ring light, to shelves full of regular stobe heads.
I use two battery driven solutions ... a Profoto Acute B 600R for less demanding, one light location use with reflectors for bounce ... and an all weather Hensel Porty 1200 2 head box ... the only non-Profoto lights I own ... but I use this mostly with umbrellas on location so the need for duplicate light modifiers aren't an issue. This kit is a tank, and I also use it with the highly portable Hensel Carbon Fiber ring-light with a handle ... recycle is lightening quick with the Porty Premium 1200 AS/RC ... and it comes with a on camera sender that allows separate control of each head.
IMO, the drawback of the Acute B 600R is that it only powers one head. Today, I would opt for the new, small Broncolor A2R which powers two heads and uses tiny but powerful Picolites which are the size of a pop can.
I also use a full set of Profoto Hot lights for special applications ... especially on location when using an ambient light selective focus approach. Set up outdoors, they turn any window into sunny Sunday summer afternoon light streaming in on the subject.
Light modifiers: for the most part I now use Profoto light modifiers which are built much more heavy duty than most anything I've ever used ... a wide array of different things to solve most any lighting challenge (rather than list them all, see pics below.)
I would like to make special mention of Gary Register's Plume "Wafer" Soft-boxes to fit most any system. I use two of his units ... one for overhead and the other for full length people shots. My in-home studio is limited in space and Gary's "Wafers" minimize the depth of the soft-boxes without sacrificing light quality. The only draw back is that they are not easily torn down and set -up. They are pretty much fixtures in my studio. However, I do have Profoto and Hensel rings to use these boxes on either system.
http://www.plumeltd.com/waferrect.html
I also still use the Elincrom Octa as well as a number of Modifiers I already had from my Elinchrom system. The Octa breaks down and sets up almost as easily as an umbrella for location work ... but you need a whopper of a light stand to hold it.
Applications: My studio applications vary widely, from precise product work for clients like American Axel and GM, to more evocative select focus food for Unilever, to animation sequences, to corporate portraits, to situational people shots on to be cut out and placed in stock shots for layouts (a good reason for Hasselblad's software super imposition and live view.) ... and so on.
Obviously, each job requires different lighting solutions. However I have a basic table top set-up I leave in place for quick solutions. It consists of a coved milk glass plex shooting table, with lighting arrayed around it top, bottom, back and side. I can vary the amount of light from any direction for quick but diverse solutions. The D4s allow very refined selection of light levels to create subtile shifts of lights and darks. Most of this lighting is broad but directionally specific, and I then use reflectors, mirrors and small degree grids for specific areas of interst ... plus often apply "subtractive" lighting techniques ... where you light broadly, then begin blocking the light with strategic placement of silks, flags, and so on.
(A special note for bottom lighting: a ring light is fabulous for bottom lighting because it lays so low to the ground. It can be used as a broad source or large grids can be used to concentrate the light more.)
Well, I could go on and on, but that more than enough for now
