Results 1 to 3 of 3
Thread: elinchrom quadra with softbox
    764
    I have been using the elinchrom quadra with an extra small chimera softbox. I jst shot a quick test with the elinachrom quadra portalite made for the quadra . It gave me a about 3/4 of a stop more light and was just a touch harder does this make sense. The portalite is much more shallow and the difference is so slight in terms of quality the porta is defitnily a bit harsher. But is smaller and easier to deal with it is about 4 inches less wide and the same height.
    Senior Member atanabe's Avatar
    Napa Valley, CA
    470
    2
    Re: elinchrom quadra with softbox
    The Elinchrom boxes have a shiny crinkled foil lining that sharpens the light. You can also add an additional internal diffuser to soften the light.
    Al Tanabe my website https://www.altanabe.com
    Kemzo
    Quote Originally Posted by dseelig View Post
    You can add the white, translucent, or silver deflector inside and that'll make the light more softer and pleasing. I tried the deflector before, and it reduces the light output so drastically that I had to remove it. Try it, you have them.
