Results 1 to 11 of 11
Thread: Comparing dinosaurs: Metz60CT-4 & Quantum Qflash Model T
    May 2009
    296
    Both the Metz 60CT-4 (GN 197) and Quantum Model T Qflash (GN 160) are powerful old dinosaurs that run off their own battery packs. The Metz has a higher guide number but the surface area of the built in reflector looks considerably smaller than the scoop that comes with the Quantum.
    If bouncing either of these flashes into an umbrella, would the difference in the size of the head and reflector make any noticeable difference in softness and evenness of the light that ended up on the subject?
    In theory it should but maybe in the real world there is no significant difference?
    boastudios
    Re: Comparing dinosaurs: Metz60CT-4 & Quantum Qflash Model T
    Hi, there is no difference, once it goes through full diffusion or bounces.
    I have been a user of 60 CT-4s since '88, and have three. So fast to work with, with 1/3 click stop dial on top going to 1/128 or 1/256. I mainly use in manual mode. Work great into umbrellas or Chimera softboxes with their mount. Have used them with 16x22" to 54 x72". I also bought some lighter-weight rechargeable packs especially fitting these, that I think are Lithium Ion, and they work well.
    Back when I started to shoot for magazines, supporting my way through school, I would go around town on my bicycle, with two of these, radio slaves, two stands, and a softbox, with my film Hasselblad...all fitting into a LowePro backpack, and shoot spreads and covers.
    Aug 2008
    Carmel/Tucson
    2,355
    I have a couple of Quantum Qflash T2---which is basically an updated Model T. Great quality light, fast and easy to use. The Qflash is an attractive portable lighting kit because it readily accepts many different lighting modifiers and is easily attached to a lightstand. Plays well with Pocket Wizards.
    ken
    May 2009
    296
    .....there is no difference, once it goes through full diffusion or bounces....
    Thanks boa and kd for answering my question. :-)
    Looks like both the Metz and the Quantum are both fine systems with differences mainly in the details rather than to do with the "quality" (evenness, softness) of light they produce, which seems to be not too negatively effected by the size of the Metz 60CT flash head if all the positive reports about it are true -- though have not heard from anyone who has had opportunity to compare both of them (flash) head to (flash) head.
    I did read one comment on an ancient forum thread that a photog had complained to a dealer that his 60CT unit produced results with brighter concentration of light in the center of the picture and fall off towards the edges that according to him the dealer had confirmed was a problem with all these units so he swapped to a Quantum system and became a happy chappy as his problem disappeared - but maybe the problem arose because he was shooting the powerful 60CT flash straight at his subjects rather than bouncing or diffusing it; my guess is doing this would be softer with the Quantum that has a built in diffuser so perhaps the problem he mentioned is more more to do with the photographer than the gear (as usual).
    Another question I have is how complicated and fiddly is it to deal with the dial on the top of the 60CT head? I understand all the theory but am not sure how easy it will be to navigate the (non-illuminated?) dials in a working situation compared to the Quantum's user friendly LCD?
    Aug 2008
    Carmel/Tucson
    2,355
    Let me preface my following comments by stating I don't have any experience with the Metz 60CT, but I do have extensive experience with the Q.
    Absent the use of larger modifiers, I simply like the round parabolic type reflector better than the squarish speedlite type reflectors. I find the quality light is more pleasing. You can easily remove the Q reflector and shoot barebulb (better for beauty dish light dispersion than rectangular-type flash heads), use different reflectors, use gels easily (slips between the two diffusion panels). I think of the Qs as a portable "bridge-system" that nicely straddles between speedlites and better studio lighting. Sometimes you want more than what speedlites offer; sometimes you just can't/want to haul around bigger studio lights.
    The LCD panel is very easy to navigate---and if given the option, get the T2 over the model T. The T2 will "hold" your previous settings which is convenient.
    I've never had a desire to use all the bells and whistles offered by the latest generations of Qflash, so never upgraded. IMHO, the quality of light from all the Qs is the same---so as long as you don't need the bells and whistles, that old dinosaur of a Qflash remains a reliable piece of portable quality light kit.
    see, www.qtm.com
    ken
    May 2009
    296
    yes :-) but :-( ...with still very expensive battery, right.
    May 2009
    296
    yes :-) but :-( ...with still very expensive battery (fair enough for quality kit)
    Aug 2008
    Carmel/Tucson
    2,355
    Quote Originally Posted by lowep View Post
    The Q can use any of the Quantum Turbo line of batteries. So with an original Turbo battery, it's actually pretty affordable. I've only had to recell my Turbos a couple times. Obviously the newer generation of Turbo batteries (Turbo 3 and Turbo sc) are more costly, and are more desireable considering their smaller size and weight. You can find affrodable used Turbo batteries and simply re-cell them if needed---and they will operate as new. I've never upgraded my Turbo batteries as I don't use the Qs that often now...
    ken
    8,498
    44
    I've owned both flashes ...
    I preferred the bare bulb flash over the speed-light design for most every application.
    Try this test like I did ... use shoot through umbrellas and dial down the flash ... get on the other side of the umbrellas, stop down and shoot toward them so you can see the light pattern and concentration from the umbrellas.
    It is also a lot easier to mount the bare-bulb units on camera to retain the light over the axis of the lens to drop shadows behind the subject. Plus even mounting a potato masher speed-light to a stand is more complex than with the more common configurations needed to mount the Q flash.
    I like the bare-bulb with parabolic reflector, beautiful quality of light. Tons of different modifiers for the Q flash ... and most fit other bare-bulb units like the 120J and Hasselbald D40. I still use a 120J with all kinds of modifiers.
    -Marc
    Sethboy
    Quote Originally Posted by boastudios View Post
    I have been a user of 60 CT-4s ........ . I mainly use in manual mode. Work great into umbrellas mount. ....
    I've had quite a bit of difficulty finding out proper information on how to mount a 60CT-4 onto an umbrella swivel. How do you normally mount yours to keep the flash head centered with the umbrella shaft? Do you use a standard umbrella swivel, or have you come across some kind of bracket or custom (or DIY) design?
    Pictures links and info appreciated.
    I've come across a few threads dealing with using the camera mount plate, turning it backwards, mounting sideways, all seems a bit confusing.
    May 2010
    168
    The 60 CT-4 has a 1/4 20 thread in the bottom of the handle. Mount a super clamp onto your light stand. Use an extension arm from the clamp to mount the flash. Tilt and swivel the head to center it in your umbrella.
    http://www.manfrotto.us/product/8373...p_without_Stud
    http://www.manfrotto.us/product/8373..._with_013_Stud
