Results 1 to 7 of 7
Thread: Beginner - Equipment for product photography suggestions
    Aug 2009
    220
    Hi
    I am a designer that has just been asked by a client to start doing small to medium sized product photography for them...ie downlights and powersupplies. They are more than happy to pay for the equipment to get things going with the intention that I can keep it after I work off the hrs for it which I don't mind doing.
    They are after a more artistic take on their products with lighting so I think that can allow me to get some equipment that I can use to start practicing fashion editorals which is my main interest.
    Was wondering if someone can give me some recomendations for lighting setup, light modifiers, light stands, tent (if needed) for this application. My current equipment list is;
    Panasonic Lumix GH2
    1xOlympus FL50-R flash
    Flash modifer kit (softbox, snoot, honeycomb, dish, etc..)
    1xComer 1800 LED Portable Hot shoe light
    1xStand + 40" White umbrella
    Cactus V5 remote triggers
    What I think i need to buy:
    1x boom light stand thingy
    another light stand, maybe two
    some lights for the light stand
    a light tent
    some light modifiers?
    a dedicated table
    What I would like to have reason to buy =):
    a boom light stand with maybe a dish
    another flash
    another stand and umbrella or soft box
    a backdrop kit
    I don't want to get too much if its not essential so I can work it off quicker but I'd like to get the most out of the offer. Thanks in adavance
    Cheers.
    Member Greg Lockrey's Avatar
    Temperance, MI
    141
    Re: Beginner - Equipment for product photography suggestions
    Based on what you have already and not knowing what type of products you will photographing this item comes in several sizes and works like you're a "pro".
    http://www.bhphotovideo.com/c/produc...um_Cocoon.html
    You being a designer it should be a snap for you to get the product photo and then "photoshop" in the backgrounds.
    Subscriber Member kit laughlin's Avatar
    Two suitcases and the latest MBA
    1,334
    And what lenses do you have for the GH2—for that work, I am sure you will need the 45/2.8, and it's a great lens.
    Aug 2009
    220
    thanks for the replies. Yep, I think a medium sized light tent is the way to go and i am considering just lighting it up with a couple large articulating armed desktop lamps for easy adjustment.
    this is the sort of product lighting my client is after. quite artistic and dramatic which is great. I think one or two shots are superimposed.
    http://www.coolon.com.au/images/prod...ial/cp96-1.jpg
    http://www.coolon.com.au/images/prod...ial/cp96-2.jpg
    http://www.coolon.com.au/images/prod...ial/cp24-4.jpg
    http://www.coolon.com.au/images/prod...unnelled-3.jpg
    can i achieve this look with a light tent? I am thinking its easier to achieve open aired with backdrop and a couple strobes/spots with diffuser setup? This is something else I would like an opinion on, strobe vs hot lights? hot lights come more natural to me as i have a video background but i would like to play more with strobes.
    products will be no bigger than two coffee mugs side by side.
    as for my lenses, they are as follows;
    lumix 14-140
    lumix 14 f2.8
    lumix 20 f2
    lumix 7-14
    lumix 100-300
    contax zeiss 28 f2.8
    contax zeiss 35 f2.8
    contax zeiss 50 f1.4
    contax zeiss 85 f1.4
    tamron 90mm macro f2.8
    *would love to get the 45 some day =)
    thanks again for your input.
    8,498
    44
    No, you cannot achieve that look with a light tent. The pics you showed as examples are far more controlled in terms of light placement than is easily achieved with a light tent, if at all.
    The lighting used for the shots you posted is most likely done with a strategically placed, boomed soft-box or more likely something like a Profoto Pro box which has a soft light, but harder edge than the typical soft-box ... combined with a light using a snoot/grid ... and some use of bounce surfaces and light killing flags. They appear to be done on a shooting table using matte black or slate vinyl or plex surface.
    The size of your products indicates that a 2X3 boomed softbox would work ... and a snoot with a grid to highlight select areas. You'll also need a third light for the glancing back light that spills around some of the edges. Not all shots you linked to used all of these, but some do. You should have the option.
    -Marc
    Aug 2009
    220
    thank you very much Marc for the analysis. It seems alot more involved than I had originally thought. I will have to re-think the setup again with your suggestions.
    thanks
    hot lights vs strobe?
    8,498
    44
    Quote Originally Posted by MRfanny View Post
    thanks
    Actually it isn't all that involved IF you have the right tools. Most lighting solutions are relatively simple and involve careful placement of the light to illustrate the product ... and what is not lit is often just as important.
    Strobe or hot lights?
    Strobe. When shooting smaller items using soft-boxes you'd be amazed the amount of light required to retain enough depth-of-field ... and soft-boxes or bounced light does eat some of the light.
    -Marc
