Results 1 to 18 of 18
Thread: Broncolor Move 1200 L Issue
    May 2014
    44
    Hello,
    I would like to know if other Broncolor Move 1200 L users have the same issue that I have with my unit.
    When I use my Broncolor Move 1200 L with a MobiLED plugged in when plugged into the charger and plugged into the wall outlet when power time-out occurs it will lock up the unit. I am not able to turn it on by pushing the power on button. I have to remove the battery and put it back in before I can turn it on.
    Broncolor told my dealer that they were able to reproduce this but that it affects all units and that there is no fix other than not letting it go into power time-out while plugged into the charger and plugged into the wall outlet.
    I’d appreciate hearing from other Broncolor Move 1200 L owners to see if my experiences are isolated or not.
    Thanks!
    Senior Member aztwang's Avatar
    Mar 2011
    Phoenix, AZ
    371
    Re: Broncolor Move 1200 L Issue
    Cant say I have had that problem. Do you leave the charger plugged in all the time? I ask because it's not good for the battery. I will try to your set up and see if I can reproduce the issue.
    Don
    Sep 2010
    UK
    1,387
    Hi Dennis, as I said in my PM, no issue with my pack locking up after auto shut down while charging with either a 50% battery charge or 100% battery charge. My packs are running software version 48.05, are yours the same?
    Gareth
    May 2014
    44
    Quote Originally Posted by aztwang View Post
    Don
    Hi Don,
    Thanks for checking your unit. It doesn't always lock up after powering down, so if you could try it more than once I'd appreciate it. It does occur frequently enough for me that I can reproduce the problem.
    I have it plugged in when I'm doing a photo shoot since I do long shoots. If I recall correctly from the manual, I am supposed to be able to use it when it is plugged into the charger into the wall outlet (charging).
    Thanks!
    Dennis
    May 2014
    44
    Quote Originally Posted by gazwas View Post
    Gareth
    Hi Gareth,
    I'm using prog.version 48.05.
    The problem doesn't occur after every power down but happens enough that I am able to reproduce the problem. If you would keep checking I'd appreciate it.
    Thanks!
    Dennis
    Sep 2010
    UK
    1,387
    Tried it 6 times now and not a single lock up.
    May 2014
    44
    I forgot to mention that the issue occurs when I have a MobiLED plugged in.
    May 2014
    44
    Hi Gareth,
    Did you have a MobiLED plugged in when testing? I forgot to mention that before.
    Thanks for testing! It will help when I follow up with Broncolor/HBI.
    Dennis
    Sep 2010
    UK
    1,387
    Quote Originally Posted by dennishuang View Post
    Hi Dennis, yes a single MobiLED head plugged into the pack while charging set to lowest power (if that makes any difference).
    Not heard of this before but does sound very strange especially considering your dealer said Bron's response was they knew of the problem and it effected all packs...... apart from mine and Don's?
    Good luck
    May 2014
    44
    Good luck
    Hi Gareth,
    Thanks for letting me know. My dealer was not aware of the issue until I let them know. The dealer spoke with Broncolor. Broncolor informed my dealer that the issue affects all Moves. Broncolor was unwilling to replace my Move. Hopefully your and Don's testing will help me when I speak with my dealer and Broncolor.
    Thanks!
    Dennis
    May 2014
    44
    My dealer (Capture Integration) informed me that they are able to replicate my locking issue with the Move that they have on hand and that they will contact Hasselblad Bron Incorporated (HBI) again. When I had inquired about this issue in the past, Capture Integration had said that HBI reported that the Move is not designed to be used while charging and then go to sleep. That sounds like a rationalization to me.
    Before I had purchased the Move, I had researched the product. I've attached a portion of the Move manual about operating the unit while charging.
    Name:  Broncolor Move 1200 L Operation While Charging.jpg
    May 2014
    44
    I haven't heard back from HBI if this issue affects all Moves or if there is a fix.
    Mar 2011
    Phoenix, AZ
    371
    I tested both my packs today for Steve over at CI and they do not lock up. I had MobiLed plugged in and had Modeling lamp on for 15-20 minutes and popped a few test flashes before I let it go idle on the charger. One suggestion I had was you may possibly have an older battery/older firmware as I remember when I had one of my packs upgraded to RFS 2.1 I had to send the battery in also as Bron had to change firmware in the battery as well. I'm not sure how to tell firmware edition, may have Steve ask Solomon over at Hass/Bron service.
    Don
    Sep 2010
    UK
    1,387
    Hi Dennis,
    Just an update, I have three Move packs and have now tested them all and can confirm one is effected like yours. The other two were purchased together at a later date and I cannot after multiple ettempts get it to happen on these packs so as Don suggests they must have done something to the packs or battery.
    I'm going to put the older battery in the newer packs and test again and vise versa with the older battery. My original pack is probably two is years old so similar to yours.
    Thanks, Gareth
    May 2014
    44
    Don
    Hi Don,
    Thanks for the update! I appreciate the testing.
    The pack firmware shows prog.version 48.05. I don't know if there is a way for me to see the firmware version of the battery.
    I'll check with Capture Integration again.
    Dennis
    - - - Updated - - -
    Hi Dennis,
    Thanks, Gareth
    Hi Gareth,
    Thanks for the testing!
    That would be great if you could check the packs with the different batteries!
    Dennis
    Jun 2014
    4
    After seeing this post I was curious if my Move pack and MobiLED was affected as well.
    I tested it 4 times and it locked up once. The time it did lock up I waited approximately 5 minutes before powering it back on. Possibly waiting that 5 minutes caused the battery to go into deep sleep mode or something.
    Member Jay Emm's Avatar
    Dec 2010
    Australia
    93
    8
    Same issues. Happened again last night - nasty failure as it added a thermal error to the mix and stood down for 20 minutes. I'm over the Move. Hired studio, model good to go, and my lights have failed. WTF? Avoided embarrassment because I didn't trust these things and had alternate lights in my car outside. Seriously not good enough for pro lights. For any lights actually, but at this price point it's deeply frustrating.
    May 2014
    44
    Quote Originally Posted by Jay Emm View Post
    I am sorry to hear about your problems with the Broncolor Move. I had sent it to Hasselblad Broncolor Inc but they couldn't fix it. I ended up having to buy a new one for a different reason. I haven't done extensive testing of the new one but I haven't run into the issues with the new one that I had on my previous Move.
