Results 1 to 4 of 4
Thread: profot soft boxes, grr!
    Brooklyn
    4,043
    1253
    am struggling to dis-assemble a couple of these, 3' x 4' fitted with speed ring. cannot seem to pop the struts out of the ring no matter how much i twist and flex (the struts, that is).
    any advice?
    thx
    Mar 2008
    Brooklyn NY
    457
    8
    Re: profot soft boxes, grr!
    any advice?
    thx
    I have the octa and they are tough. I've found that I have to remove all the baffles and front silk completely, undo any velcro around the neck, this allows for flex in the shape of the box which gives enough room to undo the rods. Also do opposing sides and brace the opposite side against a wall or something that you can push against to flex the opposite rod while you pull out the opposing rod.
    but really mostly it was take all the other stuff off that made the difference.
    Mar 2015
    16
    any advice?
    thx
    I only used the 3x4 once not long after I bought the profoto units. Some effect required to get take these things apart. But I latter learned that the best way to install and take apart the softbox is by doing it in diagonal orders. Hope it helps.
    Aug 2010
    SF bay area
    27
    The tips mentioned above are good ones. One other thing when pulling the wands/rods/struts from the speed ring, is to try to keep the wands/rods/struts heads as parallel as possible to the hole so as to make the entry/removal as smooth and effortless as possible. When one tries to remove them when the wands/rods/struts are at an angle, there is a lot of friction. I find this removal method to be useful with other lighting equipment brands as well.
