Results 1 to 5 of 5
Thread: Profoto D1 vs Broncolor Siros
    Apr 2016
    California
    Hello hello!
    I've seen a wealth of information here, so I figured I'd come ask my questions
    I'm currently in the market for studio lights. I've been using an Elinchrom 600S and an Elinchrom Ranger RX set with one head. I recently sold the Ranger RX as I wasn't really shooting on location often enough to justify having that light. I also really despise the Elinchrom mount, which, in my opinion, is one of the worst designed things in photography.
    Now I'm looking at buying either the Profoto D1 or the Broncolor Siros. I primarily enjoy using large light sources as you can see in most of my work here: RAJ BHARDWAJ
    I've used Profoto Compacts and the Profoto B1 before and recently rented the Broncolor Siros. I loved the Broncolor Siros. I always thought Broncolor was very expensive, more so than Profoto, but recently I found out that it's not really the case with the Siros.
    I sometimes rent the Profoto Giant as I get a good deal on it. I'd eventually like to rent/buy the Broncolor Paras. I can rent the Profoto for $50/day and the Paras for about $150-$175/day.
    If I get the Profoto, I can use any modifier (speciality or not) from any brand. If I get the Broncolor, I'm pretty much set with Broncolor speciality modifiers.
    I believe the Siros are better lights (better color consistency, exposed bulb, 9 stop range vs 7 stop range). If I get the Profoto, I'd be annoyed with the recessed lights (I don't hear great things about them).
    Any suggestions? Thank you!
    kdphotography's Avatar
    Aug 2008
    Carmel/Tucson
    2,612
    Re: Profoto D1 vs Broncolor Siros
    Both Profoto and Bron are considered top quality lights.
    If the recessed tube of the B1 or D1 is an issue, you obviously need to swap in the glass dome. See, http://www.bhphotovideo.com/c/produc...me_for_D1.html
    The Profoto Acute cap works to provide protection when not in use.
    Ken
    Mar 2015
    16
    Quote Originally Posted by raj View Post
    Hello hello!
    The non recessed tube will likely to have slightly better light quality in some modifiers. Go with Siros if you need them now and if the Bron system works for you, or wait for a few months to see what will Profoto bring to the table.
    Jan 2017
    3
    Quote Originally Posted by FelixWu View Post
    Very true. I just wrote a review comparing the two and the Bron Siros creates soter more even light than the D1 in some modifiers. But the dome on the D1 really doesn't make it the same as a pro head or a Siros in the right modifier. http://johngress.com/broncolor-siros...00-air-review/
    N.S. Canada
    2,179
    Agree with John above. We had a mix of old and new Profoto gear, packs and monolights - including D1s, B1 and B2 - all with domes (except B2 obviously). While the recessed light has it's advantages for travel, etc., they aren't great in any modifier that needs more than a 70 deg spread of light. BDs, large boxes, Paras, certain 'tin' reflectors, etc. With a dome it's better but not the same as the 180 deg spread of an exposed tube. Call it splitting the difference between no dome and old style.
    It got so annoying having to parse out lights on a shoot depending on what worked best with certain mods, that we sold all our recessed units and moved to just 'old-style' Acute & Pro packs & heads plus some older Compact monolights.
    It really comes down to what you primarily intended to shoot, what mods typically used, budget etc., By all appearances, the Brons are nice, but have no experience with them.
