Results 1 to 7 of 7
Thread: Elinchrome light questions
    Member bavanor's Avatar
    Apr 2009
    Bozeman, MT
    65
    All you Elinchrome owners do you know the difference between the Ranger RX and the Digital RX systems? What does one give you over the other?
    Aaron
    1,513
    Re: Elinchrome light questions
    Aaron,
    Though not an Elinchrom user, aside from their Rotalux Octaboxes, the first obvious difference between the Ranger RX and the Digital RX systems is power source. The Ranger system is battery operated for portable use. The Digital RX is an AC/mains power pack to which you connect heads. The output, recycle times, total power output, range of power control (number of stops), etc., will be greater on the pack and head system than the battery powered system for the most part.
    Elinchrom has an updated site (http://www.elinchrom.com/) that has a lot of very good information on their systems. It is definitely worth the look if you are interested in these very good lighting systems. Others, like Guy or Bob, may be able to add more, since they use Elinchrom stuff. I have Profotos, but do use the Elinchrom light modifiers for some of my shooting, just not the heads, packs, or battery systems. If you need portable, the Elinchrom Ranger RX or their new Quadra system is very nice. If you are in a studio, or setting where you have power, the Digital RX packs with Digital heads would be a good choice also.
    LJ
    Apr 2009
    Bozeman, MT
    65
    Thanks LJL for the reply. Aaahh, that little bit helps me a lot. Though for some reason my brain was not processing that information from elinchrom's website.
    For my use I would want the battery power capability.
    Another question, it seems to me that you can only hook up 2 lights to the Rangers, is this correct or is there some splitter cable to hook up more lights?
    Aaron
    23,623
    2555
    Only two lights per pack. Not sure about any splitter cable
    www.guymancusophotography.com
    Los Altos, CA
    10,486
    1031
    Two lights per pack and Elinchrom does not make a splitter, but some third party may. On the packs, you can buy them as symmetrical output -- or equal power at each head -- or asymmetrical which is 33% power to one head and 67% to the other for a 1:2 lighting ratio.
    Additionally, you can mix A and S heads. The A (Action) head fires in half the time as the S (Standard) head, so when you combine an A head with an S head, the effective output of the S head is cut in half. Thus, these two heads on a Symmetrical pack will generate a 1:2 lighting ratio. However when used on an Asymmetrical pack, they can generate a 1:1 ratio OR a 1:4 ratio depending on which ports you plug the heads into. Maybe a bit confusing to read here, but definitely adds flexibility to the system
    home: www.getdpi.com
    Apr 2009
    Bozeman, MT
    65
    Thanks Jack, that is some valuable information on the heads and packs. Something to play with there and to think about.
    Aaron
    aprillove20
    Anyway, the Ranger system is battery operated for portable use.
