Results 1 to 10 of 10
Thread: Best tool to clean IR and CCS for my mamiya ZD
    Dec 2009
    Italy
    5
    Best tool to clean IR and CCD for my mamiya ZD
    Hi guys,
    happy new year to everyone. This is my first post after a period of "only reading". I learned a lot .... seeing your pictures and following threads.
    My name is Roberto, 45 years old, living in north west Italy very near the France border..... Shame on me for poor english !!!!!!
    I purchased my first MFD equipment used (mamiya ZD with 3 lenses) and everything works like expected. I am very happy with overall quality. There are some small dusts (nothing of terrible... with few clicks using Capture One ... et voilà) on the IR filter or on the ccd (i don't know where .. think on the filter because the first owner told me he never removed the ir).
    Could you suggest me something to do a good and safe cleaning of IR and CCD? It may be the "arctic butterfly 724 brite" a good choice?
    Tnx in advance for every idea and happy festive season,
    roby
    Mamiya ZD + 35 + 80 + 150 + 55-110
    8,498
    44
    Re: Best tool to clean IR and CCD for my mamiya ZD
    Quote Originally Posted by rrkradio View Post
    Hi guys,
    roby
    Welcome Roberto. Your English is much better than my Italian
    I use the Arctic Butterfly to remove loose dust. Lint free Pec Pads are best for further needs. I just breath on the protective IR filter and lightly remove stubborn spots. There are solutions made for further work cleaning the IR.
    IMO, do not try to clean the actual sensor ... that should be done by an expert in a clean room.
    -Marc
    Dec 2009
    Italy
    5
    -Marc
    Hi Marc,
    thanks for you fast reply. I'll buy the Arctic 724. I suspected that was unsafe to clean at home the CCD...
    enjoy your last day of 2009,
    roby
    4,333
    Re: Best tool to clean IR and CCS for my mamiya ZD
    Sitting here this morning reading the newest posting while “Rocket Man” is playing on the radio. I share this as my first thought was trying to blow the dust off the IR with a hand blower.
    Wlcome to the forum and Happy New Year!
    Don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    Hi Roberto,
    Regarding the dust, you should be able to tell if the spots are on the filter (inside or outside) or on the sensor as the ones on the sensor will be in focus, meaning showing clearly with hard edges.
    The best test would be shooting a white wall or an opaque filter and then pushing the contrast.
    If they look soft then they're on the filter. You would normally be able to see them with a loupe or a magnifier and to determine if they are inside or outside...
    Good luck and Buon Anno!!!!
    Los Altos, CA
    10,486
    1031
    Stage 1 = rocket blower or DRY canned air on IR filter.
    Stage 2 = rocket blower on all surfaces.
    Stage 3 = Eclipse and pec pads followed up with the blower.
    If you have to go to Stage 3, then I'd clean all 3 surfaces; the CCD and both sides of the IR filter.
    And welcome to the forum!
    home: www.getdpi.com
    4,333
    Even in the dusty conditions I normally shoot I’ve found that my dust problems are normally fixed with the rocket blower.
    Don Libby
    Blog
    Tucson AZ
    Dec 2009
    Italy
    5
    Tnx for your help. Dust is not sharp ... edges are difficult to detect. Therefore i will try with the Arctic to clean the ir without removing it from the camera ..... after that ... i'll ask you guys.
    Happy new year,
    roby
    Dec 2009
    Italy
    5
    Arctic 724 arrived. Now is much better, but not perfect. I have some remaining dusts inside the filter, but if a remove it .... it remains in the cartridge. Therefore i can't access the other side ...... any suggestion ? or am i totally dummy ?
    Roby
    snajcziuk
    Help needed.
    I have the Mamiya ZD SLR version of the camera. [not the removable back version]. I see a menu function for CCD cleaning, but don't see that it does anything? I can remove the infared filter, but can not figure out how to 'see' or access the actual sensor. Does anyone know how to do this, or have the manual?
    Thank you
    Darryl
