Results 1 to 3 of 3
Thread: H1/H2 firmware update
    Jan 2010
    381
    I have both an H1 and H2 along with a Phase One back (P45+). Is there any way to get the firmware updated short of sending the cameras back to Hasselblad? I live in Orange County, Ca.
    I might add that it is a privilege to be a new member of this community. You guys are terrific.
    Last edited by cerett; 24th January 2010 at 07:20. Reason: Added new member comment.
    Jan 2010
    528
    Re: H1/H2 firmware update
    Find someone that has a Hasselblad back which fits your back (CF, Ixpress) and you can update the firmware via that route. Hook it up to your computer, boot Phocus and update the firmware (naturally you have to download both Phocus as well as the appropriate firmware).
    Jordan_Miller
    As Dustbak mentioned, this can be accomplished with using a CF/CFII or Ixpress series Hasselblad digital back. In addition, this can also be done using an H3D/H3DII digital back as well.
    Bear in mind, the latest firmware versions for the H-series camera bodies can only be installed via Phocus. FlexColor is not compatible here. Additionally, the Imacon/Hasselblad Ixpress backs are also not fully compatible with Phocus. In short, your best bet is find a CF/CFII or H3D/H3DII back, the latest version of Phocus, current firmware from Hasselblad, and someone familiar with the firmware upgrade process.
    Considering your location, I would suggest you find a local Hasselblad dealer, as they will most certainly be able to take care of it. With the right items (see above), this process will take just a few minutes, and should be of little to no cost.
    I have attached a PDF copy of the readme file associated with the latest version of H-series firmware.
    Regards and welcome to GetDPI,
    Jordan
    Quote Originally Posted by cerett View Post
