Page 3 of 3 FirstFirst 1 2 3
Results 101 to 106 of 106
Thread: Hassy H4D/40 Release
  1. #101
    Nov 2008
    UK
    561
    Re: Hassy H4D/40 Release
    Quote Originally Posted by David Klepacki View Post
    Thanks Nick. That is what I expected.
    In the end, the entire issue of focusing accuracy comes down to the consistent production of lenses with dead on focusing ability that neither are back-focused nor front-focused and in which every lens element is centered. Otherwise, the entire focusing chain is thrown off, as the True Focus mechanism will just propagate any such errors in the lens itself.
    Leica seems to have to go to a lot of trouble to ensure their lens consistency. I am still curious as to how Hasselblad achieves the same thing, and without the same costly effort as Leica.
    Basically, Fuji are extremely proficient at lens manufacture and often underestimated in this field.
    Add this with mechanical precision of aligning the sensor, fine tuning of the AF system to compensate for any mechanical intolerances, compensation of the IR cover glass, AF compensation for different Apertures and True Focus...
    ...gives you a very good auto focus system.
  2. #102
    492
    My question is why does it seem that so many Leica lenses are delivered that need to be sent back due to focusing issues? That "costly effort" doesn't appear to correlate directly with actual results. I'll forego the litany of Leica lens experiences ... suffice it to say that the theory of high production costs doesn't necessarily mean anything.
    -Marc
    Yep, exactly right. Focusing issues will always be there in any lens production, no matter who does it and how costly.
  3. #103
    Feb 2010
    2
    I just posted my thoughts on the H4D 40 on my blog.
    I have the same questions about the high iso performance of the H4D-60 - I guess I will find out when I can take some test shots with it and compare.
    Elizabeth Carmel
    www.ElizabethCarmel.com
    www.TheCarmelGallery.com
  4. #104
    Jun 2009
    1,347
    12
    Graffitti to show ISO performance?
    It's a bit hard to tell noise from the pigments
    However this one and the ISO1600 posted on Lum.Landscape are by far the best high ISO shots from MFD I've seen by now.
    Would love to see some more high ISO samples of the H4D40...
  5. #105
    tetsrfun
    I wonder how much improvement is due to hardware and how much is Phocus 2.x. I recently intentionally underexposed at ISO 400 using my "ancient tech" CFV back and then "processed" using Phocus 2.x. I was surprised as how much better the noise levels were compared to my previous experience with ISO 400.
    Steve
  6. #106
    Melbourne, Australia
    2,338
    52
    Quote Originally Posted by gogopix View Post
    So, Peter, is that the chracteristic of the H series that bubbles to the top, in your mind?
    No - bu tit is the funniest one liner I could think of after wading through this thread...
    Haselblad has a very good total system - thta is what I liek about the system. Nothign is the 'best' it just all works together very well. - and no other system is any better.
    The only problem I have is the clever way Hassselblad incorporate the improvements they wish to make in a way that forces upgrades of considerable cost. i would have been perfectly happy to keep my 39 megapixel back and just buy a body for example but now it is a choice of ugrading a body and a back - to get the benefit of the focus trick..
    I am thinking an artec and a couple of rodenstocks will suit me better - same cost and now I can get an artec which will take my H back...
