Results 1 to 5 of 5
Thread: Hasselblad Service Center
    Jan 2010
    381
    I need to send my H1 and H2 to the Hasselblad Service Center in New Jersey for firmware updates. I cannot find anyone in the L.A./Orange County area I know or trust to do it. Apparently they will check out the entire camera. Anyone have any experience with them? Are they reasonable? Any other changes that need to be made to improve compatibility with the P65+ (whatever that means!). Thank you.
    2,794
    Re: Hasselblad Service Center
    I sent my H1 in a number of years ago for upgrade H1 to H2....they did a great job at a reasonable price but took twice the quoted time.
    Not sure that the upgrade kits are available anymore and the H1 may have limited compatability with the P65+ at least H2 should see ISO etc.
    No one else in the country was be able to do the upgrade in the past.
    Bob
    Jan 2010
    381
    When they did the conversion, did the H1 now say H2 above the battery grip?
    2,794
    Cannot remember but I think so...the LCD did say H2 Upgrade when booted up.
    Understood that it was a circuit board and related to battery on grip powering back if Hasselblad back.
    Bob
    z0624
    I've sent my H1 in for an overhaul after having some weird electrical issues. They went over everything with a fine tooth comb and replaced some boards. It now has the latest firmware. When I sent it in, they only had the "Check to Spec" program for the V-series. Now it's also for the H-series which is what you're essentially going to be getting. Turnaround was fast and communication was good. H1 is running like a champ again.
    http://hasselbladusa.com/media/18359...to_spec_v4.pdf
    Regards
