Results 1 to 13 of 13
Thread: Hasselblad H4D 50MP vs. Phase one P45+
    Feb 2009
    793
    I am not trying to campare apples to oranges or decide which is better, rather under what conditions or styles of shooting would the hasselblad and phase one P45+ be better suited. I am looking to buy one or the other, using a bank loan and want to choose wisely, based on which would better suit my needs(landscape mostly, few portraits, some macro and conversion to black and white images)
    23,623
    2555
    Re: Hasselblad H4D 50MP vs. Phase one P45+
    Big price difference here to start. I would assume the P45+ is used and the H4D 50 is new. Technically they are different as well the P45+ is 6.8 micron the 50 6. This one is tough to compare we are in a situation where the P45+ is older tech , ISO 400 is not something to write home about but it can do a 1 hour exposure. Everything else on the P45+ like shoot speed is also slower but this is a awesome back. Now here is the issue and I'm a Phase shooter the 50maybe the better way to go but more money obviously use a newer 6 micron sensor better effective ISO speeds. Lets say ISO 400 is very good most likely faster to shoot and a new body that has some interesting tech but will cost you more. This really is a apple to coconut choice. One is going to be a lot cheaper to get used they other has no used option yet. Personally if it was between system than maybe a P40+ because nothing exactly matches the 50. The real comparison right now maybe the 2 40's from each OEM but in this case if your actually going to get a bank loan than I would go for the latest technology you can to hold its value as long as the bank loan is. So in essence if you need to sell than you can at least be selling the latest technology.
    www.guymancusophotography.com
    23,623
    2555
    I guess maybe in part we should ask why these two choices. Not that they are bad but the reasoning behind it so it maybe easier to evaluate the need and prices you are looking at. One might be you don't want a 1.3 crop sensor which some folks don't like which the 40's has.
    8,498
    44
    I agree. Apples and oranges. The H4D/50 is the latest tech, but the P45+ on a new Phase One camera is no slouch
    A few questions:
    Do you favor wide angle lenses. I mean like 24 or wider on a 35mm camera? If yes, than the 1.3X cropped frame 40MB options guy mentioned may not be the best choice.
    Do you think you may want to use a tech field camera? If yes, then I'd select the Phase One P45+
    I'm using a H4D/40 ... and can say the H4 camera is worth every penny. True Focus is terrific for off-center compositions even in the studio, and for shooting environmental portraits.
    Is it possible that you could stretch to a P65+
    Also, have you explored the possibility of a lease to own program? Saves all the interest payments and at the end you buy it for $1.
    -Marc
    Jupiter, Fla.
    1,967
    2
    If you decide on the H4D/50 Marc's suggestion to explore the leasing option is a good one. Last time I looked there was also a trade-in promotion for that kit. If it's still available you might be able to save yourself some money by picking up a cheap qualifying used back and trading it in at a higher allowance.
    Feb 2009
    793
    I do like wide angle, so the P40+ is out. i have been offered a great price in the Hassy H4D 50 with the hassy 28mm lens, a bit more money(not much)than a cambo wide/P45+ and 35mm lens.
    thanks for the advice.
    23,623
    2555
    How wide do you need to go. On a P40+ a 28mm is about a 21mm on a FF 35mm system
    23,623
    2555
    Quote Originally Posted by felix5616 View Post
    But that is such a different breed of cam. Hard to compare like that, you can do a Cambo with any of the backs Hassy or Phase.
    Simple case you can buy a P40+ kit or Hassy HD4 Kit for 22k or less. Than you can add a cambo to either kit with a 23mm or 24mm if need to get extremely wide.
    8,498
    44
    Grab it if you are getting such a good deal including that lens! You can always get a tech camera later and use the back on it.
    After seeing the results from the new sensors, I'd like to add a 50 to my bag myself. Here we go again ...
    -Marc
    Feb 2009
    793
    Can the 50MP hasselblad back form a H4D kit be used on a cambo wide or is it matched/designed only for the H4D body? what is the longest exposure possible on a hasselblad H4D 50MP back?
    23,623
    2555
    The one niggle with Hassy backs is you need a external image bank which are 2k and it is something you have to connect to the back.I'm sure this is still the case with the 50 mpx
    http://www.bhphotovideo.com/c/produc...e_Bank_II.html
    digital FEatURES
    Sensor size
    Sensor dimensions
    image size
    File format
    Shooting mode
    Color definition
    iSO speed range
    Storage options
    Color management
    Storage capacity
    Capture rate
    Color display
    Histogram feedback
    iR filter
    acoustic feedback
    Software
    Platform support
    Host connection type
    View camera compatibility
    Operating temperature
    dimensions
    Weight
    CaMERa FEatURES
    Camera type
    lenses
    Shutter speed range
    Flash sync speed
    Viewfinder options
    Focusing
    Flash control
    Exposure metering
    Power supply
    Film compatibility
    50 Mpixels (61328176 pixels)
    36.749.1 mm
    RaW 3FR capture 65 MB on average. tiFF 8 bit: 150 MB
    lossless compressed Hasselblad RaW 3FR
    Single shot
    16 bit
    iSO 50, 100, 200, 400 and 800
    CF card type U-dMa (e.g. Sandisk extreme iV) or tethered to Mac or PC
    Hasselblad Natural Color Solution
    4 gB CF card holds 60 images on average
    1.1 seconds per capture. 33 captures per minute
    Yes, 3 inch tFt type, 24 bit color, 230 400 pixels
    Yes
    Mounted on CCd sensor
    Yes
    Phocus for Mac and Windows
    Macintosh: OSX. Windows: XP (32 and 64 bit), Vista (32 and 64 bit), Windows 7 (32 and 64 bit).
    FireWire 800 (iEEE 1394b)
    Yes, Mechanical shutters controlled via flash sync. Electronic shutters can be controlled from Phocus.
    0 - 45 ̊C / 32 - 113 ̊F
    Complete camera w. HC80 mm lens: 153 x 131 x 213 mm [W x H x d]
    2290 g (Complete camera w. HC80 mm lens, li-ion battery and CF card)
    large sensor medium format dSlR
    Hasselblad HC/HCd lens line with integral central lens shutter.
    32 seconds to 1/800 second
    Flash can be used at all shutter speeds.
    •HVD 90x: •HV 90x:
    •HVM:
    90 eye-level viewfinder w. diopter adjustment (-5 to +3.5D). Image magnification 3.1 times. integral fill-flash (g.No. 12 @ iSO100). Hot shoe for SCa3002-system flashes from MetzTM. 90 eye-level viewfinder w. diopter adjustment (-4 to +2.5D). Image magnification 2.7 times. integral fill-flash (g.No. 12 @ iSO100). Hot shoe for SCa3002-system flashes from MetzTM. Waist-level viewfinder. Image magnification 3.2 times.
    autofocus metering with passive central cross-type sensor. Ultra focus digital feedback. instant manual focus override. Metering range EV 1 to 19 at iSO 100.
    automatic ttl centre weighted system. Uses built-in flash or flashes compatible with SCa3002 (MetzTM). Output can be adjusted from -3 to +3EV. For manual flashes a built-in metering system is available.
    Metering options: Spot, Centre Weighted and CentreSpot. Metering range Spot: EV2 to 21, Centre Weighted: EV1 to 21, CentreSpot: EV1 to 21
    Rechargeable li-ion battery (7.2 VdC / 1850 mah).
    No
    Nov 2008
    UK
    561
    Hi Guy,
    You don't need the Image Bank if you want to work untethered.
    A rechargeable FireWire battery device will do the job as well.
    Look at hotwire-digital.com. About $135 from memory.
    23,623
    2555
    Great David thanks for setting me straight. Was hoping you would join in on this one.
