Results 1 to 45 of 45
Thread: Mamiya ZD for IR?
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,610
    21
    Mamiya ZD for IR?
    Hi Folks, Has anyone tried the ZD (without the IR cut filter) for IR?
    I would appreciate hearing how it performs.
    23,623
    2555
    Re: Mamiya ZD for IR?
    Great question Vivek . Jack and I both have the ZD and we have not tried it yet but the possibilities are interesting.
    www.guymancusophotography.com
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,610
    21
    Guy, One fantastic possibility with this cam is the removable filter/slot.
    You can buy the original filter holder separately and plant an IR filter (or have an array of IR filters of various strengths in separate holders).
    You can also focus after having the filter in place just as usual. There may be focus shifts though.
    What is the best price for a ZD in the US now?
    It still is >10K Euros in the E.U.
    23,623
    2555
    Well 10k gets you the Mamiya AFD -II , 80 mm lens and the ZD back. Now i got a demo unit that was priced at 9 k but got a even better deal. Now the new body is coming out the AFD -III from Mamiya and Phase one so I bet you will see some AFD-II bodies for sale when that happens , mine most likely one of them. So you can still get in the door at a good price. I bought mine at Camera West but David at Dale is also a Mamiya dealer. Also Lance is here on the forum from the Capture Intergration group and he sells Mamiya and Phase backs also plus a variety of gear
    Los Altos, CA
    10,486
    1031
    I just tested this out this morning... And it works
    Bad news first: AE isn't really close, so you need to confirm exposure with the histogram.
    Good news: Really interesting -- removing the IR cut filter does alter the point of focus. But it moves it CLOSER, so there is no need to adjust focus for IR use(!) It actually FF's a teeny bit with the IR cut removed, but probably not enough to even worry about
    More later,
    home: www.getdpi.com
    Senior Member irakly's Avatar
    394
    26
    there WILL BE the focus shift. one of my students dropped a kodak back and broke the IR filter. as expected, all images without the filter went magenta and were out of focus. so, with lenses than do not have IR mark it will be trial-and-error business.
    Los Altos, CA
    10,486
    1031
    Quote Originally Posted by irakly View Post
    Read my post directly above... Yes there is focus shift, but removing the filter from the ZD basically moves the PoF enough -- and in the right direction -- to compensate for the IR focus shift. So IOW, the two cancel each other out. Pretty cool for ZD users
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,610
    21
    Jack, Thanks for checking. Is this a ZD (whole) camera or the back attached to a Mamiya AF cam as Guy has?
    Irakly: Is that DCS back with its broken IR cut filter available for sale?
    394
    26
    no, we put a new one. actually quite a story... it happened in moscow, where kodak did not have an official dealer for digital backs. the girl was desperate as she had to shoot someone for russian vogue in a few days. i chacked with kodak, and it was $1560 backordered item. i found an antialiasing filter for the original proback for $300 on ebay and fedexed it to moscow. she had it reset by a local camera wizard into a frame of the original filter for another $200. later i learned that a 72mm UV/IR-cut filter on a lens would work just fine
    Los Altos, CA
    10,486
    1031
    The ZD back on an AFDII camera. I do not know about the fixed-back ZD camera...
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,610
    21
    I was under the impression that only the Mamiya ZD camera had removable IR/AA filters. I was wrong. The back also allows for this change. That is good.
    http://www.mamiya.com/mamiya-zd-back...l-filters.html
    It is, in principle, possible to have an IR pass filter (say Hoya R72) cut and mounted instead of the IR cut filter. This would allow looking the viewfinder while framing/focusing.
    Focus shift and AE are problems with any IR shooting. While the shift can be taken care of fairly easily after calibration of a lens for a given filter, exposure is more complicated as it would depend on the light and specifically its IR content.
    ..and Irakly, thanks for your response.
    Los Altos, CA
    10,486
    1031
    Sure it is -- you just need the frame and have an 072 cut to fit. Current IR-cut is held in the frame with screws.
    Apr 2008
    110
    I wonder if Singh Ray wouldn't create such a filter for you. Or me. I am thinking of picking up a ZD setup this week, primarily because I want to move up to a larger format for infrared wildlife photography. Something that gives me this kind of look from my home page:
    http://www.andybiggs.com
    I would love to keep this thread going, if possible.
    Jupiter, Fla.
    1,967
    2
    Andy,
    Welcome to the forum, I've admired your work for quite a while and going on one of your photographic safaris is a dream of mine. Maybe someday..
    Apr 2008
    110
    Quote Originally Posted by David K View Post
    Andy,
    Thanks, David. I am truly flattered! I am trying to figure out how to move up from a Digital Rebel 400D that I have converted to infrared, and up to medium format.
    I will call Singh Ray today to see if they are up for retrofitting the filter holder.
    AlaBill
    Andy...
    Great IR photographs on your site. The line of elephants on your home page is fantastic!
    Let us know what you find out on the filter. After seeing your work, now I'm interested in the Mamiya as well.
    Los Altos, CA
    10,486
    1031
    Hi Andy, and welcome to the forums! As for the filter, try shooting the ZD with the IR cut removed first -- the file is so IR heavy at that point you may find you don't need any IR filter on lens or camera anyway
    Apr 2008
    110
    Quote Originally Posted by AlaBill View Post
    Andy...
    You can call me evil Andy. Nothing like getting people to spend more money! Thanks for the very flattering comments. I am not worthy.
  19. #19
    Apr 2008
    110
    Yeah? That would be wonderful!
  20. #20
    Senior Member JimCollum's Avatar
    santa cruz, ca
    936
    155
    anyone have any ZD IR samples they can post?
  21. #21
    23,623
    2555
    Jack shot something. So you want a shot with just the IR filter off the back only. Because i don't have any front filters right now for it
  22. #22
    santa cruz, ca
    936
    155
    color IR.. both visible and IR light (preferable in the morning before the sun has come up)
  23. #23
    Apr 2008
    110
    Quote Originally Posted by JimCollum View Post
    exactly! I am just wondering what the file will look like if I convert to B&W, and if it is worth asking somebody like Singh Ray to place a new filter in the IR filter's place.
  24. #24
    Los Altos, CA
    10,486
    1031
    Quote Originally Posted by Andy Biggs View Post
    I don't think you'll need it, seriously. One thing I noticed when I shot with the IR cut filter removed is that the glass obviously affects the light-path and point of focus. However, when removed, the focus moves CLOSER (hehe). Actually moves a little bit closer than the amount you need to compensate for the IR wave focus shift, so the two nearly cancel each other out. I ended up with focus about 15 cm closer than actual at a 3 m subject distance with normal focus --- pretty dang close for IR
  25. #25
    Apr 2008
    110
    Good to hear, Jack. Good to hear.
  26. #26
    Los Altos, CA
    10,486
    1031
    Okay, crap. Embarassed to share this but here goes. A really ugly image but taken just because of the vegetation in it to see the IR behavior under open shade with mottled direct sun patches on the grass. FTR, the grass is very spring green, the flowers are red to magenta and the other vegetation varying shades of green and that's a redwood fence in the background. I processed in ACR, color temp 2000 and tint -140. I had over-exposed by about a stop, so this is pulled back -1, everything else normal. Lens was the 80 at f8, IR-cut filter removed, ISO 100.
    The color, my B&W conversion and a crop of the B&W to show the in focus detail maintained.
  27. #27
    Los Altos, CA
    10,486
    1031
    Okay, I knew it was a butt-ugly image, but I didn't think it was bad enough to kill the thread...
  28. #28
    santa cruz, ca
    936
    155
    ok..had to go rent one of these and try it out...
    (thanks to Keeble and Schuchat!!!)
  29. #29
    23,623
    2555
    I maybe selling my ZD back to upgrade Jim. Will know after San Juan. Looks good
  30. #30
    santa cruz, ca
    936
    155
    what i'd really want is to be able to do this with the Aptus 75
    (is leaf listening???)
  31. #31
    santa cruz, ca
    936
    155
    some more tests
  32. #32
    23,623
    2555
    Probably not
  33. #33
    Los Altos, CA
    10,486
    1031
    Very nice Jim
  34. #34
    Jupiter, Fla.
    1,967
    2
    Very nice shots Jim, but I'm going to have to go with Jack's pink image above... it's just so... special
  35. #35
    santa cruz, ca
    936
    155
    Anyone else trying the ZD and IR Photo filter combo? (Jack? Andy?)
    Here's a split tone image using the Mamiya 35mm lens (which does have a hotspot, btw), and using a B&W 92 filter.
    Only Lightroom was used in the making of this image (used their split tone control)
  36. #36
    Apr 2008
    110
    Jim-
    I have done little other than take my system out of the box. I am trying to decide what my options are for lenses, as I just have the 80mm right now. More lenses are on their way.
    I need to figure out my approach with IR on the ZD.
    Should I:
    1) just remove the IR cut filter
    2) replace the IR cut filter with the filter that blocks visible light
    3) just remove the IR cut filter and replace with standard glass
    Are there any other options that I have missed?
  37. #37
    santa cruz, ca
    936
    155
    Jim-
    Should I:
    I replaced the IR cut filter with the Mamiya IR Photo filter (pretty much just optical glass). I then use the B&W 92 IR filter to remove most visible light, and get an IR image. From my Betterlight, i have a 77mm IR cut filter that i can place over the lens to get a 'normal' light image. This gives me the option of have either a normal image, a monochrome IR image, or a combination color /IR (luminosity layer= IR, color layer= normal light)
  38. #38
    Apr 2008
    110
    Jim, are you referring to the YD401 filter that replaces the IR Cut Filter that Mamiya ships as standard on the ZD back? How much was it? I know Jack mentioned he got his from Keeble in PA. If it is standard optical glass, then all it is doing is protecting the sensor. I guess. If the filter isn't that expensive, I might see if I can get a 92 filter put in it. My goal is to block visible light and also preserve the ability for me to autofocus and compose normally.
    I have also been looking into the IR false color 'look'. For those that are doing this, are they completely blocking out visible waves, or just some of them? I might not need to block anything if that is the case.
  39. #39
    Los Altos, CA
    10,486
    1031
    Andy, yes that's the filter. It is just optical glass, but it does alter the optical formula and focus. With nothing over the sensor, IR is actually pretty significantly FRONT focused instead of the normal slight back focus --- IOW you cannot hit infinity without a filter over the sensor...
    Jim likes the fact it's clear so he can do his two-shot capture of an IR and visible image for later blend. I have a Bettelight filter left over from my Betterlight days for visible too and may do the same thing, or may opt for having an 092 permanently installed in the YD401 frame and then generate monochrome or false color IR the way I normally do now with M8 files. Or I may just sell the ZD and forget all about doing IR now that I have the P45+ coming ----- need to do some testing
  40. #40
    Apr 2008
    110
    OK. Sorry for being so dense. This makes sense now. I just wish Mamiya had a filter that actually cut out visible light. I just hope Singh Ray will do the custom work for me. They have always been great at stuff like this in the past, such as when I wanted a better polarizer for my 52mm drop in polarizer on my Canon long glass.
    IR false color and/or dark skies is what I am after.
  41. #41
    Member Paul David's Avatar
    San Jose, CA
    93
    Has anyone tried using a P45+ back with an IR filter such as the 072? There was one such note quite a while ago on the LL board that while this worked for the P45 the built in IR filter was too effective to allow enough IR through. If anyone has this combination of the IR filter and P45+ I'd be most appreciative if you could give it a try.
    Thanks.
    Paul
  42. #42
    jaspersf
    Yes, a very old thread, but....
    Did anybody figure out the best way to use a ZD for IR? How to fashion an IR pass filter to insert over the sensor? I'd love to avoid covering the lens with an IR filter...
    I just bought a Mamiya ZD body, my first foray into digital MF and realized that the removable IR cut filter provides a great opportunity to shoot IR like i did with film a long time ago.
    Thanks,
    Jay
  43. #43
    Sep 2014
    Brno
    I'm now trying to use Mamiya ZD Back with IR cut filter removed.
    With 630nm IR filter it can produce nice false color images:
    The GetDPI Photography Forums - FPL's Album: IR pictures on Mamiya ZD
    For B&W conversion is better to use 720nm filter, where is IR effect stronger. Above that it's going worse - probably because chip sensitivity is lower at those freqs.
    BTW. With 3 stops down and B&W 486 filter is ZD Back with removed filter almost usable to take normal pictures - only white blance should be later corrected.
    Tiffan Hot mirror filter produced worse results - some IR is passing and it affects image.
  44. #44
    Feb 2011
    24
    2
    I bought an extra blank IR cut filter frame from Mamiya Usa and had Spencer Camera fabricate a filter to fit. You can see my Mamiya ZD IR images in my gallery here. Im using the 830um IR filter. You have to experiment with shutter speeds a bit but I usually use a -2 EV compensation and its helps.
  45. #45
    Jul 2017
    Germany
    4
    Yes, I tried with ZD Back DB.
    I just removed the IR cut-off YB401 and fixed a Kodak Wratten gelatine filter 87C in the frame of my Low Pass Filter YC401 (don't need it).
    From my experience I just need plus 1EV with this setup:
    The whole test:
    https://gosebru.ch/4-test-with-kodak...01-removed.php
    Regards
    Frank
