Results 1 to 9 of 9
Thread: blad system and older digital backs
    Jun 2008
    281
    hi all.
    i have a hasselblad 203 system and i was thinking of adding an OLDER/CHEAP digital back to it. i want to use it when i walk around, and not in a studio situation.
    can someone in the know drop some knowledge on me and tell me what is available and which is best to get and some prices?
    Feb 2010
    Southport Gold Coast QLD
    35
    Re: blad system and older digital backs
    This will work. http://www.helixcamera.com/digital/hasselblad/cfv.html. Only issue is finding one. The earlier version which I had will also work but you have to carry a image bank with its own battery around. I found it too clumsy.
    Regards Martin
    Senior Member atanabe's Avatar
    Napa Valley, CA
    470
    2
    In MF digital "Cheap" is a word needing a definition. The 203 and 205 Hasselblads can be modified at the NJ repair center to electronically connect to the CFV, CFVII and CFV39 backs and is by far the only solution for the focal plane systems. I used to have a 2000FCM and it would work using the CFV connected to the flash sync which limited capture to a maximum of 1/90th of a second. Modifying the 203 will allow capture at all speeds with the CFV back without cords. I was told by the other third party vendors, Phase and Leaf that I could not use their backs with the focal plane Hasselblads. If you had the 500 series, your options are much greater.
    Now the cheap part, used CFVs can be found for about $5500 and up, Hasselblad will from time to time, have refurb backs with a six month guarantee extendable to two years for an additional cost. While $5000 is not chump change, it is the only solution for the focal plane Hasselblads and does away with sync cords. The hard part it seems is finding a used one, or if you want to step up to the latest 39mp back, $13,000 or less depending on your retailer.
    You could also consider switching out entirely to the H system and get into a H3DII 31mp body (camera and back) for $9995. As I said earlier "Cheap" in MF digital is a relative term.
    Good luck,
    Al
    Quote Originally Posted by drazin View Post
    hi all.
    Al Tanabe my website https://www.altanabe.com
    Jun 2008
    281
    ok are there "less expensive" options for the 500 series bodies?
    also, the H3DII is that a 6x6 format? this is the format i love most.
    Napa Valley, CA
    470
    2
    The 500 series can take pretty much all of the older backs. Most all have to be tethered with a PC sync cable to trigger the sync of the back. The Phase P20 and P21 were square format I believe. But the H3DII is a 645 format as most of the modern backs. The CFV 39 is also a 645 format with the option to use the square crop. The CFV backs have a 1.5 crop factor reducing the capture to the 4x4 central area. There are no full frame 6x6 capture options.
    Jun 2008
    281
    damn. i guess i will just stick to film!
    NYC
    3,275
    7
    Quote Originally Posted by atanabe View Post
    H20/P20/P20+ are square. Every other Phase One is rectangular. The P20 can be combined with a mask for the viewfinder which reduces the viewer to the size of the square chip.
    An H20 could be had for a few thousand but would require you to tether to a computer and has a 1.5x crop from 6x6.
    Dicomed's BigShot was the only 6x6 back made. It was first made in 1996 and I mention it here only for those with an interest in the history of digital backs.
    Doug Peterson (e-mail Me)
    __________________
    Phase One, Leaf, Cambo, Canon, Apple, Profoto, Eizo & More
    Newsletter: Read Latest or Sign Up
    RSS Feed: Subscribe
    Buy Capture One at 10% off
    Personal Work
    dng88
    If you use only non-FE lens i.e. CF or even C lens, can 203 FE be used with focal plan shutter with other backs?
    tetsrfun
    Quote Originally Posted by dng88 View Post
    The 203FE set to "C" lenses and a CF lens + sync cable works fine. I think with this set up, the focal plane shutter acts in a similar fashion to the rear curtain in the 500 series.
    Steve
