tom in mpls
Quick question, is the P30+ available in a mount for the Hasselblad 203FE?
Isn't that a standard Hasselblad V mount? Sure they are.
So, in a word ... NO.Here is what I got off of the Phase One Konowledgebase:
"hase One backs will work on a Hasselbad 200 series body with a special workaround. The shutterwheel on the body needs to be set to "C" in order to disable the built-in shutter. Only C, CB, CF, CFA, or CFi lenses can be used. These lenses have a built-in shutter. This way the camera will operate like the Hasselblad 500 series cameras.
The CF lenses work on the Hasselbad 200 series camera bodies in the following way: the focal plane shutter must be locked open on the body and the leaf shutter in the CF lens is used just like on a V body.
Phase One backs designed for Mechanical Hasselblad (V-series) are compatible but with the following limitations.
# 201 F - Does not work with FE Lenses. Use C, CB, CF, CFA, or CFi lenses
# 202 FA - Not recommended
# 203 FE - Does not work with FE Lenses. Use C, CB, CF, CFA, or CFi lenses
# 205 FCC - Does not work with FE Lenses. Use C, CB, CF, CFA, or CFi lenses
For information on the use of your Hasselblad 200 series camera with the lenses mentioned above please refer to the documentation that came with your Hasselblad camera."
You can also of course if you would like to use your FE lenses go the Mamiya 645AFD route wirth the HB adapter.
L
Lance Schad
Capture Integration - Miami/Atlanta
305-394-3196 cell | 305-534-5702 office
Capture Integration
My Blog
[email protected]
I think it may well be a simple timing issue. When using the CFV back where the V cameras activate the CFV mechanically, you have to use the menu to tell the back which camera is being used. If you leave the menu selection on 500 series when the back is on a 200 series camera, it will not work.The real answer is that ONLY other cameras (Contx, Mamiya, maybe Hy6) will use both C and F lenses.
What is the issue with FP shutter on 200? I guess it is a synch issue.
I wonder how Phase does it with these cameras; the shuuter opens at different speeds-I guess the back waits for the time end and then reads out.
With the 200 I can see where the back may not start collecting fast enough? but that makes no sense
maybe someone can explain why these shutter/MFDB issues come up
regards
Victor
