Results 1 to 3 of 3
Thread: H3D flash advice
    Workshop Member kuau's Avatar
    Apr 2009
    Park City, UT
    1,071
    34
    H3D flash advice
    I need to get a flash for my H3D-39
    I am going to be doing outdoor family portraits
    Hasselblad recommends Metz with the sac 3902 adapter
    Is this a good solution
    Steven
    Steven Kornreich
    www.kuau.com
    8,498
    44
    Re: H3D flash advice
    Quote Originally Posted by kuau View Post
    Steven
    Yes, that is correct ... and the best solution I know of for on-camera flash with the H camera. Once mounted, the camera takes over all functions such as compensation, etc.
    If you are going to do portraits frequently, you may find a shoe-mount limited in possibilities, but for casual fill needs it is fine.
    I use a Metz in the shoe in conjunction with a battery powered strobe. This is needed when the shoe-mount isn't up to the power needed to balance the ambient lighting. Plus strobes allow placement of light where you want it rather than flat front-on lighting. Shoe mounts are typically 80-90 w/s max, where a modest battery strobe is 320 or 400 w/s.
    Here is an example:
    Extraordinarily bright and hazy day at 2PM placed the subjects in the only shaded area available, (I often can't pick my time or place when shooting a wedding). Key battery strobe light directionally placed camera left, on camera Metz used for fill. Without enough light on the subjects, the background would have been over-exposed, and the dappled light from the trees falling on the subjects would have made them look like Dalmatians : -).
    -Marc
    Apr 2009
    Park City, UT
    1,071
    34
    Marc,
    Which model Metz do you use on shoe-mount Camera? What is your opinion of the larger Metz 76?
    In reagards to battery strobes and preference? I need something that will work in cold weather, snow.
    Steven
    Steven Kornreich
    www.kuau.com
