Results 1 to 3 of 3
Thread: Flashmeter compatible with profoto AIR ?
    May 2009
    Marseille, FRANCE
    972
    Is there any flashmeter around that is compatible with the Profoto AIR system ?
    as my Sekonic R was compatible with pocket wizard... and my FCM with Broncolor...
    N.S. Canada
    2,010
    Re: Flashmeter compatible with profoto AIR ?
    While Gossen intro'd a fancy (e.g. over-kill) digital meter at Photokina with an Eli Skyport built-in, no AiR cards for any meter as yet, but keep your fingers crossed. Until then stuck with hanging one off the meter - or use a Sekonic w/PW card to trigger an AiR transceiver via a spare PWII, etc.
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Probably the best option is a spare transmitter that you use to fire the flash as you meter in flash-detection mode with your sekonic. That way you can use the transmitter for light adjustments if you want.
    I use a similar setup with the Elinchrom skyport system.
    -bob
