Results 1 to 8 of 8
Thread: Capture One 5.2.1 - LCC
    Jun 2009
    1,347
    12
    just saw there's a new C1 version.
    I reverted from 5.2 to 5.1.2 as the LCC analysis was really slow (due to the analysis of dust spots). It takes 4 seconds or so for my P45 files on 5.1.2 and 20 seconds on 5.2.
    Is the LCC analysis faster in the new 5.2.1 release?
    (Don't want to install and try it as I did a clean uninstall when I reverted form 5.2 back to 5.1.2...).
    Thanks!
    Oct 2010
    Zug/Zurich (Switzerland), Dubai, Sydney
    334
    Re: Capture One 5.2.1 - LCC
    you should post this on the Phaseone.com forums. You will get a prompt and well informed reply from the no-nonsense team at phase one.
    B
    Los Altos, CA
    10,486
    1031
    Thomas, I find LCC in 5.2.1 just as fast as 5.1 if you leave dust un-checked.
    home: www.getdpi.com
    Jun 2009
    1,347
    12
    also whith the initial analysis of the LCC file? How can I disable the dust spot detection prior to applying the LCC to a file? The handling of files is fine as soon as the LCC is created - it's only the initial analysis that takes some time (~20 seconds with P45 files).
    Is that different on you system?
    Los Altos, CA
    10,486
    1031
    Okay, got it -- Sorry, I misunderstood your question. Yes, the initial analyze does take about 20 seconds for my P65+ files too. The application of the LCC is fast though.
    Jun 2009
    1,347
    12
    okay, good to know - thank you!
    So I won't upgrade now. I hope they add a setting to enable/disable the dust spot detection.
    It's a great feature! But if you don't need it and if you have to make several LCCs from a shooting the slow analysis is a bit annoying.
    Los Altos, CA
    10,486
    1031
    Quote Originally Posted by thomas View Post
    Agreed, they should make it optional on the dust spot read. However, I do not use LCC very often to begin with, so it's a non-issue for me, and I actually might use it MORE just for the dust feature! IOW, one LCC frame read at the beginning of a shoot for any camera applied to every subsequent frame, and you have auto dust removal for all images which is pretty cool IMO.
    Sep 2010
    Dallas/Novosibirsk
    632
    Hmm.. i may look into LCC profiling for real after reading this. I normally didnt use it at all.
