Results 1 to 10 of 10
Thread: Hasselblad 120 CB vs Cfi ?
    May 2009
    Marseille, FRANCE
    972
    i've read many things about CB lens... and test some !
    the 60 is similar to the Cfi
    i've compare a 80 Cfe and a CB... the problem of the CN being contrast in the angles of the 6x6... i've found it to be better than the Cfe with my digital back (36x48mm)
    i've test a 160, and wasn't really impress... it was ok at F11, otherwise not a nice rendering
    Now, i'm in the process to buy a 120 macro for artwork reproduction (3D) and macro
    is the 120 CB similar to the Cfi ? i can't find any data for that lens !
    I've read that the Cfi is less prone to flare than the CF... so i skip the CF... but Cfi still quite expensive.
    I've seen a 120 CB for 800$, but i need to make shure that is as good as the CFi....
    Aug 2009
    314
    3
    Re: Hasselblad 120 CB vs Cfi ?
    Hi Archivue, there is no such thing as a 120mm CB. There are 120 cf lenses but the CB series was only 60, 80 and 160 (Distagon, Planar and Tessar).
    KEMPTEN / GERMANY
    1,513
    116
    Quote Originally Posted by H3dtogo View Post
    There was a CB120mm , but that was only for (I blieve) the american market . But it exists . I have seen one .
    The CB Planar 2,8/80 has 6 lenses while the CF , CFE and CFi version has 7 lenses .
    Regards . Jürgen .
    Aug 2009
    314
    3
    Indeed Jürgen, there was a 120mm CB and it never showed up on the european market. I always tought it was only a designstudy and never went in production but apparentely it does exist.
    Aug 2010
    Maryland
    475
    There's an active thread on photo.net about the 120 CB lens:
    http://photo.net/medium-format-photography-forum/00Xd2s
    - Leigh
    KEMPTEN / GERMANY
    1,513
    116
    Quote Originally Posted by Leigh View Post
    - Leigh
    The thread in photo.net has almost the same text .
    Therefore I assume the author is the same person than archivue .
    Regards . Jürgen .
    Aug 2010
    Maryland
    475
    Exclamation Re: Hasselblad 120 CB vs Cfi ?
    The thread in photo.net has almost the same text.
    Perhaps the OP is the same, but the respondents are different.
    - Leigh
    May 2009
    Marseille, FRANCE
    972
    yes, i've post it in several forums... my names are archivue or sacripant... still didn't find the information i was looking for !
    the only 2 informations i've found was a photographer that find that the 120 CB wasn't as sharp as his 120 CF... and an another one that find that the front element in the part catalogue between the CFi and the CB is different...I think i will buy a cfi...
    May 2009
    Marseille, FRANCE
    972
    my names are archivue or sacripant... and "dg" or "David G"... ;-)
    tetsrfun
    There is a CB120 listed at KEH.
    Other than the electrical contacts, are there any optical/mechanical differences between the 120 f/4 CFE and CFI lenses?
    Steve
