Results 1 to 17 of 17
Thread: Hasselblad V users: Tripod head?
    Oct 2008
    Canada
    163
    I shot in studio for the first time last week with my Hasselblad 553ELX/P30.
    I was using my Manfrotto 322rc which I use for my dslr but I found it terrible when trying to keep the body level. I hated it.
    Any suggestions from the Hasselblad users here?
    Apr 2008
    Seattle, USA
    400
    Re: Hasselblad V users: Tripod head?
    I used my Hassy on a RRS BH-55 with lever release clamp. Not in the studio, mind you, but I found it to be an excellent combo for the nature work that I do.
    Feb 2009
    1,083
    6
    Quote Originally Posted by BradleyGibson View Post
    Which Hassy do you have, and which plate do you use for that head? I look at RRS and i don't know which plate i should use for 500 series [501CM].
    Tareq
    tetsrfun
    Quote Originally Posted by Dolce Moda View Post
    If you have a Gitzo series 3 tripod or RRS tripod then I would suggest the RRS leveling base with the PCL-1 clamp. On my last road trip, I used this combination 95% of the time; the BH-55 stayed in it's bag. This is an easily leveled platform and very stable. In the few situations where I wanted to have a camera angle > 15 degrees from level, I just shortened one tripod leg.
    And then there is the "Cube", which is another story..:>)
    As far a RRS plates for 500/200 series, I use a B82 (even though it is suggested for collard lenses) or the B22.
    http://reallyrightstuff.com/Items.as...ssy1/4&key=cat
    Steve
    May 2009
    Marseille, FRANCE
    972
    An arca D4 seems to be a good option now !
    May 2009
    Marseille, FRANCE
    972
    Apr 2008
    Seattle, USA
    400
    Quote Originally Posted by Professional View Post
    I used a 500C/M and a 203FE. On them, I used RRS's B22 plate as shown below. (Please excuse the poor quality webcam pics).
    I prefer plates with safety stops, so even if I screw up, I get a second chance (thankfully, I've not needed it yet). This plate only has it at one end. Other than that minor issue, I found it was a perfect match--fit flush to the body, the anti-twist flange worked as advertised, and did not interfere with camera operation in any way (ie. centered on optical axis and did not interfere with back changes.)
    tetsrfun
    My 203FE only has a 1/4" "hole" in the tripod plate so I used a reversed B82 rather than the 3/8" B22. FWIW, with my 503, the tripod plate is higher than the 203 and the B82 will mount in normal manner,
    Steve
    Feb 2009
    1,083
    6
    So B22 or B82?
    Tareq
    tetsrfun
    So B22 or B82?
    I prefer the B82; it's longer and narrower than the B22 and covers the underlying 'blad tripod plate. The B82 screws into the 1/4" socket and the B22 into the 3/16" so theoretically the B22 is a "stronger" plate, FWIW.
    Steve
    Feb 2009
    1,083
    6
    Quote Originally Posted by tetsrfun View Post
    Steve
    I am really confused which one to choose, i also prefer the longer one, but if the other is stronger this is also an advance, so don't know if longer will be better than stronger somehow, i am afraid to buy both then, lol.
    Tareq
    8,498
    44
    When I shot V cameras I HATED any additional QR mounting plate on the bottom of the camera itself.
    There is a flush quick release plate already built into all Hasselblad cameras, and I used the Hasselblad Tripod Quick Coupling H for all V, H and X cameras which can be attached to any head you want. It has leveling bubbles built into the QR unit, a lever release, and a safety catch pin that uses an indentation in the built-in mounting plate. VERY secure, yet fast to dismount.
    http://www.bhphotovideo.com/c/produc...d_3043326.html
    -Marc
    Oct 2008
    Canada
    163
    Thanks Marc
    I will be picking up one of those for sure
    Senior Member bensonga's Avatar
    Alaska
    2,416
    819
    -Marc
    I use the Hasselblad Quick Coupling unit also. I prefer it mounted on the Gitzo 2270M head. This works really well for a camera as heavy as the 553ELX.
    Oct 2008
    Canada
    163
    Is the Hasselblad Quick Coupling Plate S required to mount the camera on the unit? It is sold separately for some reason.
    Thanks Ben, I am going with the Gitzo 2270M. It looks like the best option to keep the camera level. I shoot beauty/fashion. I want the camera perfectly level to save cropping headaches.
    8,498
    44
    No. The plates are made available so you can add them to other cameras or lenses with a collar/foot and use the same QR tripod. I had S plates on every camera I owned when I shot V cameras.
    If you are located in the USA, I can sell you the QR unit for $100. and extra S plates for $20. each. I don't shoot a V camera anymore and don't need as many as I now have. Just PM me.
    -Marc
    Jerusalem, Israel
    1,282
    This won't suit everyone, but I replaced the thin sheet metal coupling plate on my 500 C/M with Joe Codispoti's $50 Clearsight plate. It's thicker, and fits the standard RRS, Arca, Markins clamp jaws. For multiple Hassy's and one tripod, it might be simpler to use the Hasselblad QR plate, permanently affixed to that one tripod. And Hassy purists at Photo.net will be less offended.
    This does not address the leveling issue.
    scott
