Results 1 to 11 of 11
Thread: Fixing MF Moire
    Aug 2010
    New Jersey, USA
    509
    Fixing MF Moire
    Posting here because I really haven't seen serious moire in my dslr work in a long time so it's more of an mf thing.
    Did a search here and didn't come up with many fixes for moire in an image.
    Anyone have any suggestions or techniques or links to moire fixing on web?
    Attachment 38018
    Sep 2010
    Dallas/Novosibirsk
    632
    Re: Fixing MF Moire
    yes, its called Capture One - there is tool for that
    Aug 2010
    New Jersey, USA
    509
    Re: Fixing MF Moire
    I did see that in C1, but I'm not smart enough or have enough time to learn another program. Not kidding.
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Re: Fixing MF Moire
    Quote Originally Posted by David Schneider View Post
    Well, that is maybe the easiest way that I have found.
    -bob
    Apr 2009
    Sydney, Australia
    581
    2
    Re: Fixing MF Moire
    Are you using Phocus? I thought that its tool was good.
    Jeff
    www.jeff-grant.com
    Aug 2010
    New Jersey, USA
    509
    Re: Fixing MF Moire
    I'm no Pocus expert, but it was run through Pocus with no changes to image at all. Then opened in Photoshop.
    Apr 2009
    Sydney, Australia
    581
    2
    Re: Fixing MF Moire
    It looks like it is on but set to 0 by default. It's under Noise Filter in the Adjustments panel. Moire used to be a hot topic a while back but I haven't seen it mentioned in quite a while.
    Jeff
    www.jeff-grant.com
    Aug 2010
    New Jersey, USA
    509
    Re: Fixing MF Moire
    Jeff,
    I'll try that and see if it helps. Thanks.
    Dec 2009
    Germany
    3,658
    Re: Fixing MF Moire
    At least you can get rid of the color moire:
    1. Photoshop
    2. Duplicate layer
    3. Strong blur or Dust&Scratches
    4. Change Blending Mode to "Color"
    Uwe Steinmueller
    http://www.outbackphoto.com
    Aug 2010
    New Jersey, USA
    509
    Re: Fixing MF Moire
    Uwe,
    Thanks. Worth a try and a whole lot easier than learning C1.
    May 2009
    Singapore
    240
    7
    Re: Fixing MF Moire
    I think the Phocus method is even easier...just click, and choose from 5 levels, and then export as PS Layers PSD, so you can mask out the unaffected areas in PS. Works very well for me.
    Though, many thanks Uwe for sharing this technique.
