Results 1 to 10 of 10
Thread: Error Code 04 - Mamiya AFD II
    Sep 2010
    Philly area, PA, US
    354
    Today I was shooting and all of the sudden the shutter got stuck open. After a couple of seconds it closed (it sounded like when you are in bulb mode or really long exposures).
    Right away, the top display showed Err 04, advanced the film and the counter went from 15 to 1 (film back). Right after that started working again (I took another shot and then manually re-winded the film). Batteries were not fully discharged or blinking.
    Any idea what that Err 04 means?
    Sep 2010
    Philly area, PA, US
    354
    Re: Error Code 04 - Mamiya AFD II
    Nobody has any info what this error means? I've searched around and couldn't find anything about it.
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Valentin,
    No, sorry I don't.
    -bob
    Sep 2010
    Philly area, PA, US
    354
    Quote Originally Posted by Bob View Post
    Valentin,
    No, sorry I don't.
    -bob
    Thanks Bob. It seems that Mamiya wants to keep this a closely guarded secret .
    I have a 6 month warranty on this but it would be inconvenient to send this in (especially if they can't reproduce the problem) but at the same time I would hate to have the camera stop working right after it expires.
    Vancouver, WA
    5,803
    564
    Have you tried giving the folks at MAC group a call? I believe that they service the US Mamiya equipment (amongst others). They may tell you to send it in but it's worth a try ...
    4,333
    I vaguely remember having a problem "sorta" like this and what I needed to do was re-seat the batteries by popping the holder out and reinserting before it cleared. This was many years ago and not entirely certain it resulted in a Code 04 but offer it just the same.
    Don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    Sep 2010
    Philly area, PA, US
    354
    Thanks Graham and Don.
    Another gentlemen PMed me and he mentioned the batteries as well. That could definitely be the problem. I used the Eneloop rechargeables and I shot about 10-15 rolls with them. I have to keep an eye on how many rolls I can go through with a set of batteries.
    sdz
    Hello everybody, I know this is an old thread but I now have exactly the same problem and perhaps someone found a solution for that?
    I have an AFd ii with two different film backs. I used normal alkaline, eneloops with 2700mAh and I cleaned the contacts also but its all the same. I also replaced the batterys in both backs. I have the issue with every roll in both backs. The counter is set back to "--" so I loose the photo that was stuck and the camera winds up the film afterwards also, so i loose at least two shots so this isnīt merely annoying.
    Best regards, Sebastian
    Feb 2009
    518
    Throwing in a guess here, since you are not getting other answers...
    Both you and the OP (Valentin) said that you were using rechargeable batteries - these normally output 1.2 Volts rather than 1.5 V. So the set of 6 is supplying 7.2V to the camera instead of 9V. That might be a factor?
    Ray
    Santa Monica, CA
    2,275
    2
    What Ray said: there's a thread somewhere about which batteries to use.
    See http://www.getdpi.com/forum/medium-f...able+batteries
